Page 1 of 6 12345 ... LastLast
Results 1 to 10 of 51
    Jan 2009
    Tucson, AZ
    Default Car will only shift when OFF
    So I did my first clutch swap recently and thanks to you guys, everything went pretty smoothly.
    I fired her up today, but when I went to put the car in gear, it wasn't going to happen. I turned the car off and noticed I could shift the gears while the car is off, even without pushing the clutch in. So I shifted the car into first, started it, and I was able to drive. But as soon as I put the car back into neutral to shift into another gear, it just would not go into another gear. So here's a break down of the problem:
    1. I can shift the transmission, with the car off, without even using the clutch.
    2. The car will not shift once started.
    3. If you shift the car into gear (while off), then start the car, you can drive in that gear.
    Someone PLEASE help the newb.
    ThatAdStudent.com - Advertising and Graphic Design Blog
    1993 Camaro Z28 M29 - Down for Repairs and Upgrades
    my 3 little angels
    Jan 2009
    charlotte,nc
    when you start it in 1st does it take off even with the cllutch pedal in??
    JASON.C '97'm6,pro 5.0,k&ncai,bbk52mm w/bypass,magnaflow cats,flowmaster c/back,strano springs,kyb agx shocks, lca relocate brackets,hounds tooth 30th interior,70k
    Long Live the Opti
    Sean
    1999 Twin Turbo Corvette
    Fort Wayne, IN
    Agree with Tarheel Z. I'm thinking your clutch isn't disengaging.
    Jan 2009
    Tucson, AZ
    Quote Originally Posted by Tarheel'Z' View Post
    Nope. You gotta give it gas to get it going.
    Someone mentioned the possibility of the clutch disc being on backwards, but would that cause this problem?
    Long Live the Opti
    Sean
    Fort Wayne, IN
    Quote Originally Posted by Counted Out View Post
    quite possibly as the offset of the center section is different. But......you would have had a hell of a time reassembling the clutch if that was the case. I've seen one put back in backwards once, and the install was stopped because it just wasn't going together easy enough.
    Jan 2009
    Tucson, AZ
    I have a really ghetto clutch fluid cap that mite be letting air into the system. I just thought of that. So if anyone has an extra cap, PLEASE, let me know.
    I'll check it tomorrow.
    I responded to your request for the cap. Did you check with GM, since you cant find one....
    Jan 2009
    Tucson, AZ
    Did you message me on here? If so, I didn't get it.
    GM doesn't have a part number listed for just the cap.
  9. #9
    Jan 2009
    Paul Edwards
    1993 Camaro Z28
    Port Charlotte FL
    junk yards have alot of them around here, cuz the 3rd gens caps are the same. so 1982-1997 5 speed and 6 speed use the same caps, also v6 birds do too, not so sure about ls1 cars though
    1995 Formula 383/t56 gone
    1993 Camaro Z28, forged, TFS heads, solid roller, prosystems carbed, t56 swapped spec 3+
    "Nitrous is like Tara Reid with an STD. You want to hit it, but your afraid of the consequences"
  10. #10
    Jan 2009
    Tucson, AZ
    Quote Originally Posted by 95formula383lt1 View Post
    I was told that LS1's don't.
    There is only one Pick-A-Part here and the last time I went I only saw like one 4th Gen and maybe 2 3rd Gens. It mite be worth the drive out there to check though.
