Page 1 of 6 12345 ... LastLast
Results 1 to 10 of 58
Thread: Coolant leak
    Mar 2015
    Mike Storm "Stormy"
    1995 Trans Am
    Washington
    Blog Entries
    1
    Default Coolant leak
    The other day I was loosing coolant but no puddle. So I was reluctant to check it out. Plus I work on boats all week and its cold ECT... So it warmed up abit and well I miss driving the car. I checked it out, not the normal stuff, W/P, hoses. Its the water pump mounting gaskets Been 5 years Why now? Anyway going to have to wait till the weekend. Thought Id shre this with you guys. Ive never seen this maybe right after a wp install not 5 years later.
    Dec 2013
    SoCal
    try and snug the WP bolts up. It may stop the weeping gaskets
    If you pull pump for new gaskets, I always use a skim coat of the Permatex Water Pump RTV on each side of the gasket
    The lower driver side WP bolt needs thread sealer on it. Goes into water jacket.
    96 BBB 383/T56
  3. The Following User Says Thank You to BALLSS For This Post:
  4. #3
    Mar 2015
    Mike Storm "Stormy"
    1995 Trans Am
    Washington
    Blog Entries
    1
    Nope need new gaskets. It cinched up a bit changed to a pissing sound. Had to look real close to see it. I cant remember why I didn't use the fel pro ones. I think I used the ones that came with. Crap wrong time of year probably should get a new w/p too. Its been 5 years
  5. #4
    Mar 2015
    Mike Storm "Stormy"
    1995 Trans Am
    Washington
    Blog Entries
    1
    Any input on water pump now that I don't trust it. I know it was a Delco but now that Im not sure it will last. Any latest recommends would be grand thanks. Not doing the elec pump yet.
    is it the 12527741 or 251556? the later being the CHEAPER one.
  6. #5
    Johnny
    1994 formula A4
    Henderson, TN
    If the pump isnt leaking I would just reseal it and go.
    Ive put brand new pumps on and they leak... parts are hit or miss nowdays
  7. The Following User Says Thank You to fullforce For This Post:
  8. #6
    Dec 2013
    SoCal
    ^^^this.
    Op, if the WP is 5 years old and the leak is just the gaskets...re-use the "known" good pump
    and do use some WP RTV on both sides of the gaskets
    96 BBB 383/T56
  9. The Following User Says Thank You to BALLSS For This Post:
  10. #7
    Mar 2015
    Mike Storm "Stormy"
    1995 Trans Am
    Washington
    Blog Entries
    1
    Well I know its been awhile but the weather was nice today. This is hard to tell you guys being a Technition and all. But the reason my wp gaskets failed is. The center bolts where loose and probably a couple more. Oh yeah and I forgot the coil bracket bolt ug.... Its dark and all of my lights have died. Maybe this weekend Ill have good news. 5 years its been since I did the wp.
    ... on my tablet using Taptalk
  11. #8
    Be sure to use sealant on the water pump bolts.
  12. The Following User Says Thank You to Injuneer For This Post:
  13. #9
    Mar 2015
    Mike Storm "Stormy"
    1995 Trans Am
    Washington
    Blog Entries
    1
    Yes sir they are not blind. I think a couple are but might help keep the bolts tight. Got the wp sealant permatex.
  14. #10
    Mar 2015
    Mike Storm "Stormy"
    1995 Trans Am
    Washington
    Blog Entries
    1
    Well crap everytning back together, pressurer check isnt good. wont stay and no external leaks so Im fracked , Is there a way to check heater core? The floor isnt wet. Didnt have any heat the whole time i was bleeding. I know it might be the heads but im not savy on the lt1 cooling system.
