Results 1 to 10 of 32
07-24-2017, 11:37 PM #1LTX Master
- Nov 2008
- Enrique
- 93 Z28
- Houston/Clear Lake
- 615
24X, Performance Parts, Stock Parts, 383, 4L60, etc.
383 stroker with forged internals. $2500
Built 4L60. $800
TPIS headers 1 3/4 inch headers to 3in collectors. They have some dents and they have been sandblasted and coated with POR-15 high temp paint. $200
BMR K-member that is powder coated black. One of the welds broke and I had it welded again. $250
Canton 7.5 oil pan with the gasket. $200
New LT1 Melling oil pump M--55HV ($40 new) with new welded on Canton filter($37 new). $50
New LT1 water pump that was painted to prevent corrosion with gaskets. $50
LT1 water pump that's bad that the housing can be used for an electric water pump. $5
LT1 power steering pump with pulley. $30
New crank and hug bolts. $30 and I paid $32 plus shipping,
LT1 lifter spider and bones. $15
LT1 oil tube $20
LT1 alternator Sold
LT1 stock injectors SOLD
LT1 motor mounts $20
Trick Flow 7.200 .080 push rods $60
LT1 A/C accumulator mount bracket $7
LT1heater hose line$30
LT1 polished head steam crossover line $40
LT1 accessory bracket $100
LT1 A/C compressor $175
LT1 A/C dryer line to accumulator $10
LT1 power steering reservoir with hoses $25
LT1 abs module with master cylinder $50
LT1 oil pump drive
LT1 power coated thermostat outlet $15
LT1 water pump shaft coupler $30
LT1 power steering reservoir cap in real good condition $20
LT1 ARP Head bolts 12 point. Use to bolt down heads and then unbolted them. SOLD
LT1 ARP HD Oil pump drive shaft put in and not even ran. $15
Everything needed for a24X conversion:SOLD
New 24xcrank reluctor SOLD
Newcrank position sensor (attached to timing cover)Sold
cam sensor housingSOLD
New 1x cam reluctorSOLD
New Cam position sensorSOLD
New cam sensor housingSOLD
New 96-97 crank key SOLD
96-97 timing cover that's been powder coated with seals and new crank position sensor. SOLD
LS1 PCM bracketSOLD
LS1 0411 PCM SOLD
New 96-97 hub SOLD
EFI Connection ignition coil brackets with coilsSOLD
New A/C Delco LS1 coils #12573190 #D514A.SOLD
24X BP Automotive harness for a 93 F-body with A/C and MAF. This was attached buy never used. $500 SOLD
New LS1 stock MASS air flow filter $80 SOLD
New SBC valve covers $100
New Fel-Pro head gaskets
New LT1 Stainless steel throttle body bolts $8
New LT1 Stainless steel water pump bolts $15
New LT1 Rear coolant crossover pipe bolts and washers $20
New LT1 Stainless steel intake bolts $20
New LT1 Stainless steel bolts for fuel rails free if you buy something!
Polished fuel rails $50
Aluminum elbow semi polished. $40
Like New Arizona Speed and Marine 58mm throttle body that's been repolished and rebuilt. $350
Billet Specialties Push-on oil fill caps. $40
Like new (used once) Sealed Power 224-15057 oil screen installation tool. $20
LT1 throttle linkage bracket $5
TPIS intake block off plates $10
LT1 intake with injectors and fuel rails. $30
New BMR Driveshaft Tunnel brace. $40
New Craftman Wrench organizers. $5 for both.
LT1 spindles with brakes $40
Pictures coming soon!!!
For some reason my pictures are not uploading.Last edited by 383z; 01-28-2018 at 05:40 PM.
The Following User Says Thank You to 383z For This Post:
07-25-2017, 12:18 AM #2LTX Master
- Nov 2008
- Enrique
- 93 Z28
- 615
Here is a link to some pictures.
https://houston.craigslist.org/pts/6212634784.html93 Z28, 383, PI 3200, Strange 12 bolt, 3.73, Strange coilovers, suspension, and going 24X... for three years or so.
07-25-2017, 04:52 AM #3
Pm sent
07-25-2017, 06:37 AM #4Lurker
- Oct 2012
- Charlie DeBolt
- 1995 Camaro Z28 Black M6 Ttops
- South East, Michigan
- 36
PM sent for more info on shortblock.
1995 Z28 M6 LT1 Black
07-25-2017, 08:34 PM #5Lurker
- Sep 2014
- Joel
- Colorado
- 1,157
Pm sent on coolant crossovers
08-02-2017, 12:11 AM #6Lurker
- Aug 2016
- Al
- 95 camaro Z28
- queens new york
- 5
24 x still available ?
08-02-2017, 05:25 AM #7
I never got a pm back on it so I guess
08-24-2017, 11:10 AM #8Lurker
- May 2016
- Steve F
- 1993 Camaro Z-28
- Akron, OH
- 18
PM Sent
08-27-2017, 02:55 PM #9
Headers still available? Would you ship to 74134?
Sent from my Pixel using Tapatalk
08-27-2017, 03:05 PM #10
Just realized where you're located. Hope you all are safe!!
