Results 1 to 5 of 5
10-28-2016, 08:31 AM #1VIP Member
- Dec 2011
- Mark
- Altoona, PA
- 809
What Valve Covers to run with rocker stud girdle?
I will be converting to a manual rack setup and low alternator mount this winter. With hopes of finally getting my boosted engine setup installed.
I will be using a stud girdle on my rocker studs and was curious what valve cover everyone is running. I have the Cantons for F-body cars but since I'm converting to the low mount alternator and can run any SBC center bolt cover just wanted to see what everyone else is using.
10-28-2016, 09:07 AM #2Lurker
- Aug 2009
- Kyle
- '95 Trans Am
- Elizabethtown, Kentucky
- 3,033
i cant say first hand but id say any center bolt sbc fab alum covers will be fine
Kyle
The Following User Says Thank You to SexyTransAm For This Post:
12-08-2016, 10:12 PM #3
I ran the tall ss jegs covers that were center bolt, then had them notched by a fabrication shop for the alternator.
The Following User Says Thank You to Leachbuz For This Post:
12-08-2016, 10:13 PM #4
Note: my short covers would not clear a stud girdle.
12-10-2016, 04:53 PM #5
I like the jegs brand centerbolt valve covers. Cheap and look nice
The Following User Says Thank You to DirtyBird1139 For This Post:
