Results 1 to 6 of 6
Thread: new from rochester
10-30-2014, 09:14 PM #1
new from rochester
Hey guys, I just bought my 95 z28 and I love it. It's not my first f body, but definitely the fastest. Its got forged internal (stock crank) and Advanced Inductions heads and cam. It has a bult 4l60e and beefed up 10 bolt. I'm planning on spraying a small shot of nitrous at the track, and would love to see 10's although I think low 11's is more likely. I'll post pictures up in a bit
The Following User Says Thank You to 95camaro For This Post:
10-30-2014, 10:59 PM #2InActive Member
- Dec 2010
- Daniel
- 1995 Camaro Z28
- Mount Juliet, TN
- 414
Welcome. Is it your daily driver or weekend car?
95 z28- 6spd, edelbrock headers, k & n fipk, flowmaster exhaust 2othl, 160 thermostat, hypertech programmer, 182k miles and counting.
05 dodge ram rumble bee #1511- pretty much exactly the same bolt ons w/way less miles on it.
10-31-2014, 12:28 AM #3"The Rock"
Welcome to the site. We def love pics here. Tell us more about u... and since u had other fbodies... tell us bout them. Again, welcome.
11-02-2014, 08:03 PM #4
I have a pick up truck, I only drive the camaro on nice days. It will see some track time in the spring for sure.
Here's a few pictures that the previous owner took. I have stock salad shooters, not the wheels pictured but I will be replacing them soon. I also removed the front license plate bracket. I have more plans for the winter that I will post about as I work on them.
Here's some details about the car taken from the ad
"1995 Camaro Z28. Shell has 79k on it. Freshly built LT1 350, FLT(finish line transmissions) stage 3 4L60e and built rear end. Engine has Wiseco pro tru forged pistons and scat pro comp i-beam forged rods, new crank bearings and polished journals. 190cc Advanced induction cylinder heads and matching cam 226/234, comp cam springs, chromoly push rods, 1.6 roller rockers, roller timing chain, MSD ignition, Taylor over valve cover wires, pacesetter headers, Off road y-pipe to Borla ST2 exhaust, electric water pump, trick flow 58mm throttle body and ported intake, 255l/hr fuel pump & 38lb injectors. Polyurethane motor mounts. The trans is completely upgraded with a 3000 stall converter and external cooler, check out finish line transmissions. Rear end is built with 3.73 motive gears, new bearings, Alloy USA-high strength Axles and thunder racing diff covers with bearing caps support. Suspension has UMI: tower brace, sub frame connectors, rear lower arms, panhard bar, torque arm, polyurethane bushings. Has a new power steering rack, pump, fuel pressure regulator, front hawk brake pads and brembo rotors. I have 2 sets of tires for it. Has 2 new rear 275/40ZR16 Toyo Proxes TQ Drag radials, they only have 12 passes on them and are still like new. Also has a line lock. I am sure I am forgetting some stuff here.
Body is not perfect, external was originally just black, it has been painted Mercedes Chromite Black Metallic paint. Engine bay is flat black. "
I also just bought a zex wet kit and plan to run 100 shot at the track.
My old camaro was a 95 v6 3.4 that was my dd. It was a pos lol
11-02-2014, 08:07 PM #5Xtreme Member
- Dec 2011
- JeremY
- 1972 NovA
- Elsberry, MO
- 4,416
What is that color called? I like it.'72 Nova "HadeSS"
11-02-2014, 09:05 PM #6
Mercedes chromite black metallic. It's growing on me for sure! The pictures don't do it any justice
