Page 1 of 6 12345 ... LastLast
Results 1 to 10 of 56
    The FABRICATOR!
    Jul 2011
    southern illinois
    Default D1SC ProCharger kit with 12 rib setup and fluidamper
    D1SC ProCharger:
    25k miles. I just changed the oil while I had it out. For the d1sc, fbody bracket with tensioner, mounting hardware and spacers, 12 rib pulley kit (7.65" and 8.5" crank pulley, 3.75" blower pulley, belts for both setups) fluidamper (single keyway but drilled for dual roll pins) with crank spacer matched for kit, $2700. I will throw in the current g body bracket I custom made in lieu of the f body bracket if someone is putting it in a swap.
    Cold side piping (was on a g-body) with vortech mondo bov and intercooler $500. (Will only sell with the procharger setup above)
  2. The Following User Says Thank You to firebird_1995 For This Post:
  3. #2
    The FABRICATOR!
    Jul 2011
    southern illinois
    Bump with more items and prices
  4. #3
    Administrator
    @Ltconvert there's your roots blower again
    LTX Hoarder
    1994 Firebird Formula 381 stroker - Carrying the torch! - 9.64 @ 139.4mph on a 88 jet
    1994 Camaro Vert - SBE LE1 Summit 8802 Cam - The Cruiser
    1993 Camaro Z28 - 355 TC78 Turbo T56 - part out? finish?
    The wrench/driver for LTConvert's 94 Z28- Ellwein 383/LE Trickflows/ P600B / CPT Ultra Pro Race 4L60E/Holley Terminator EFI/little huff of spray
    10.16 @ 138mph. Shooting for 9.99 for Frank/Gail Cahall!
  5. #4
    The FABRICATOR!
    Jul 2011
    southern illinois
    For those interested in flow numbers and capability, the d1sc set up with the 8.5 inch crank pulley and 3.75 inch blower pulley at 6500 rpms is capable of 1365 cfms. The whipple system set up with the 8.19 inch crank pulley and 3.25 inch blower pulley at 6500 rpms is capable of 1565 cfm. The whipple has an advertised max of 1720 cfm. Yhe d1sc has an advertised max of 1400 cfm
  6. #5
    Little Rock, AR
    Very interested in the whipple setup. Please send pictures of the entire setup through PM or email. Thanks.
    97 WS6
    06 Corvette
    05 GMC Sierra
  7. #6
    The FABRICATOR!
    Jul 2011
    southern illinois
    I will get some pictures of everything that I've got and send them out to everyone interested.
  8. #7
    The FABRICATOR!
    Jul 2011
    southern illinois
    Last pic just shows my side mount setup that used 10 rib pulleys and idlers. The drive system (damper, alternator pulley, and all idlers that system used are included seperate from the main whipple kit. Forgot to add this system also has edelbrock fuel rails, and a Lokar throttle cable.
  9. The Following 2 Users Say Thank You to firebird_1995 For This Post:
  10. #8
    Man... if I wanted a bigger budget for the vette project...
  11. #9
    The FABRICATOR!
    Jul 2011
    southern illinois
    I know it....The amount of air it's capable of pushing is insane. F1-R territory, except right on tap. My goal with it was to build a new intake from scratch, run e85 and do away with the intercooler. Like I said in the first post, I have the materials, just need the time...
  12. The Following User Says Thank You to firebird_1995 For This Post:
  13. #10
    The FABRICATOR!
    Jul 2011
    southern illinois
    Bump. Lowered prices.
