Results 1 to 10 of 10
04-19-2014, 10:44 PM #1Xtreme Member
- Apr 2012
- Mike
- 96 Z28, 95 Roadmaster
- Conshohocken, PA
- 1,865
Set of 8 white Bosch III injectors, "36" 34 lbs/hr, 0280155811 and 0280155737
ALL GONE***********
I have a couple used sets of Bosch III injectors that came from various 3800 supercharged motors (L67). I checked each with a multimeter (all tested near 12.3 ohms) and was able to actuate each solenoid. They are part numbers 0280155811 and 0280155737. The injectors look slightly different but are identical in flow, offset, low pulse width, etc. They will fit on LS and LT engines and are commonly said to flow 36 @3 bar (LT). I've found that the flow rating at LT1 rail pressure is closer to 33.71 ~ 34. Some of the orings may be missing but I recommend replacing them all.
*Note - Sometimes it's necessary to double up on orings at the bottom of the injector to ensure they aren't pushed out of the rails. The retainer clips in the stock fuel rails cannot be used. Many have installed them without doubling up but I know of one car where it was necessary. This is more common on L98 engines than LT1s.
I run a set of 811s on my cammed car and they work great.
$80 shipped anywhere in the lower 48. Let me know if you have a preference of which set you'd like.Last edited by Catmaigne; 05-29-2014 at 04:24 PM.
04-19-2014, 10:50 PM #2Xtreme Member
- 7,266
Supporting Memberi have these on my car and they work great when the constant is set to 34 lb/hr, but they are double o-ringed btw
04-20-2014, 12:35 AM #3Xtreme Member
- 7,266
Supporting Memberi might need another set of these from you for the other car.
04-20-2014, 10:54 AM #4Xtreme Member
- Apr 2012
- Mike
- Conshohocken, PA
- 1,865
Cool, let me know if you want a set
04-20-2014, 05:01 PM #5Xtreme Member
- Apr 2012
- Mike
- Conshohocken, PA
- 1,865
One set is sold.
04-21-2014, 04:01 PM #6Xtreme Member
- Apr 2012
- Mike
- Conshohocken, PA
- 1,865
Bump for today. The set with both types is gone.
04-23-2014, 07:20 PM #7Xtreme Member
- Apr 2012
- Mike
- Conshohocken, PA
- 1,865
bumpin
04-27-2014, 10:27 PM #8Xtreme Member
- Apr 2012
- Mike
- Conshohocken, PA
- 1,865
still got em
05-23-2014, 12:06 PM #9Xtreme Member
- Apr 2012
- Mike
- Conshohocken, PA
- 1,865
2 sets left
05-24-2014, 04:09 PM #10Xtreme Member
- Apr 2012
- Mike
- Conshohocken, PA
- 1,865
One set left (737)
