Results 41 to 50 of 69
09-27-2016, 07:23 PM #41LTx Guru
PCM seldom fails. Just noting something I would like Gary to look at.
@GaryDoug
Before you run another data log, clear the PCM. Pull the "PCM BAT" fuse for 30 seconds. I think in 95 it moved to the box under the hood. That will clear the 160 LTFT in Cell 18. Then you have to start driving the car so we can see what's going on outside of idle.
I have a guide to what the numbers mean and what the normal readings should be. Used to be on my website, but website it long gone. I'll see if I can attach it as a PDF.SOLD - GONE TO A (VERY) GOOD HOME ! - 94 Formula A3+1: 381ci forged stroker - Callies Stealth, Oliver 5.85 billet rods, BME nitrous pistons / CNC LT4 heads / CC solid roller / TH400+GearVendors OD / 4.11 Strange 12-bolt / 300-shot N2O / Spohn Suspension / roll bar / MoTeC M48 Pro engine management system /a few other odds 'n ends.
09-27-2016, 09:36 PM #42LTX Regular
- Aug 2013
- Gary
- 1998 Trans Am
- Florida
- 241
Could be that the pc got really busy doing something else at that time. I wonder if he had the app set to auto-save the log file. Sometimes that can get slow but it is generally a gradual increase in time between scans, not an abrupt change. Best bet is to save the file at the end if fast scan time is important.
"What a PCM go for and is it a PITA?"
About $150 bucks used, but drop-in ready-to-go with your original program (bin) installed. Maybe about $100 used with the bin that came with it. If yours has been changed, someone would have to copy the bin to the new pcm. If you are just a tiny bit brave, you can do that yourself with WinFlash (free trial or $20 for long term use), using the cable you have now.Last edited by GaryDoug; 09-27-2016 at 09:38 PM.
09-27-2016, 10:13 PM #43Xtreme Member
- Mar 2015
- Mike Storm "Stormy"
- 1995 Trans Am
- Washington
- 1,020
- Blog Entries
- 1
The spike might have been when I put the computer down , and there might have been a background program running like norton
09-27-2016, 10:38 PM #44LTx Guru
I found at least a half dozen lines of data that had at least one impossible data value. As I recall, there were a couple lines in your earlier log too.
10-03-2016, 07:26 PM #45Xtreme Member
- Mar 2015
- 1995 Trans Am
- Washington
- 1,020
- Blog Entries
- 1
Well crap today went to drive up my ramps and started but no throttle. allmost like its out of gas. Before all this I had a full tank now its empty. no gas in the oil that I can smell. and is going to rain all week. No garage. Well put in 2 gallons runs got it up on the ramps for today. need oil and filter that ill have to wait. Thought I give an up date pulled the fuse for a min. And I was going to go for a drive, will do in a couple. Thanks again guys as soon as I change the oil and the o2's Ill log a drive. Before this all I ever owned where air cooled VW's and restored . @Injuneer did you find those files ?
10-03-2016, 08:32 PM #46LTx Guru
Just got back from almost a week on the road. I'll try and attach the scanner data interpretation write up tomorrow if I can.
10-03-2016, 09:11 PM #47LTX Regular
- Aug 2013
- Gary
- 1998 Trans Am
- Florida
- 241
I think this is it.
The Following User Says Thank You to GaryDoug For This Post:
10-04-2016, 07:23 PM #48Xtreme Member
- Mar 2015
- 1995 Trans Am
- Washington
- 1,020
- Blog Entries
- 1
Thats a big help thanks
10-06-2016, 07:41 PM #49Xtreme Member
- Mar 2015
- 1995 Trans Am
- Washington
- 1,020
- Blog Entries
- 1
Ok the o2 is going to half to wait cant get under car with the ramps. Being that a while ago my garage if you can call it that was broke in too. No stands so, not doing them till I can get some stands. But I did change the oil and filter apart from looking clean Mobil 1 It did smell like gas, any way went for a run got on it on the on ramp, but rush hour traffic. any way theres a short WOT and some cruzing in the scan. don't know why it only save in 1 mb at a time wasn't even set to auto save but here is a couple.
https://www.dropbox.com/s/uo4at04qf3...37818.zip?dl=0
https://www.dropbox.com/s/djczs73ns9...37818.zip?dl=0Last edited by Stormyweather; 10-06-2016 at 10:31 PM.
02-27-2017, 09:37 PM #50Lurker
- Aug 2009
- Kyle
- '95 Trans Am
- Elizabethtown, Kentucky
- 3,033
Well my datamaster is now gone. Guess I'll try the scan9495
Sent from my SAMSUNG-SM-G890A using TapatalkKyle
just ur everyday slow LT1. wanna try her out?
