Page 1 of 2 12 LastLast
Results 1 to 10 of 12
    May 2021
    Joshua
    1993 trans am
    Default Aftermarket block
    Is there anyone that makes an aftermarket second gen lt1
    May 2021
    Joshua
    1993 trans am
    I seen that post but take notice that the post has no new or updated info. Plus I reached out to a couple reputable lt1 guys asking about an aftermarket block and was told none are available nor can anyone say where or if one will ever come
    The post was updated 5/15/2021….. a few days ago. That represents the current understanding from someone who claims to know. Sure, doesn’t give you a definite “yes” or “no” but it is up-to-date. Take it for what it’s worth. Don't shoot the messenger.
  5. The Following User Says Thank You to Injuneer For This Post:
  6. #5
    Quote Originally Posted by Turbotransam812 View Post
    no, not yet. allegedly there is one on the way, but not yet. and i mean atkins/tick performance have shown CLEARLY the stock gm casting (not even an lt4 casting, a 2 bolt casting converted to 4 bolt) is MORE than capable and can survive for quite some time
  7. The Following User Says Thank You to SSlowBoat For This Post:
  8. #6
    Sep 2010
    1995 TransAm 385
    Soooo, to update on this, per "Aftermarket Ltx Block Committee" on FB a few days ago:
    "Tooling cut will be done in 3-4 weeks and the 1st prototype block poured mid to end of October. Finished product will be on display at PRI in December and available for purchase and ordering after that." This will be a 2-piece rear main instead of 1-piece rear unfortunately.
    1995 TA M6 E85
    Power mods: AFR 210 Comp Eliminators, LE LT4 intake, Custom LE cam, 12.5:1 385ci, M29
    Suspension: Koni's, 600/175lb Ground Control, 36.5/21mm sway, Fays2 Watts Link, rod-ended everything, C5 brakes, etc.
  9. The Following User Says Thank You to kgkern01 For This Post:
  10. #7
    Aug 2013
    JB
    1994 Camaro Z28 1996 Camaro SS
    Atoka,TN
    The new LTX block has been unveiled at the PRI show
    Same as everybody else...350 small block, double hump heads, 3/4 cam
  11. The Following 2 Users Say Thank You to Cathead For This Post:
  12. #8
    Aug 2013
    JB
    Atoka,TN
  13. The Following 4 Users Say Thank You to Cathead For This Post:
  14. #9
    Jun 2019
    94 Z28
    West of Chicago
    Sucks.... i just tried looking at the vid again to show my dad and buddie the possibilities coming and it put me to facebook. sorry, no interest in facebook. viglink worked before. Any links to the sales aspect of this? I am interested in helping the cause that's for sure! sorry, I'll be editing my signature soon, getting pics soon, new phone and everything. Any info would be appreciated, so I can try and kinda keep up with with you guyz????????
  15. #10
    10 Second N/A Club
    Josh
    96 Z28
    Holden, MO (KC)
    Send a message to @Tony Shepherd, he'll get you the info you need.
    -Josh
    co-owner of BDBRacing.com
    NMCA OC 9004
