Page 1 of 5 12345 LastLast
Results 1 to 10 of 48
    Jan 2012
    1997 z28 383 stroker
    oklahoma city,ok
    Default Loss of oil pressure
    Ok this is not on my car so don't freak lol this is for @f-bombmatt he said his oil pressure has been low for a while about 20-30 then yesterday he lost all oil pressure he said its at the line above zero , and today he said he thinks its starting to knock a lil (btw it's his DD so he's still driving it he don't have a choice) does anyone have an idea what went out, the car has 130k and he don't have a lot of money let try and help this guy out
    Thanks
    SMOKE TIRES NOT DRUGS
    could be anything man... we need nore detail.
    20-30 Isnt low... LT1s are acceptable by gm to idle at 7-10psi.
    With that being said...it should increase 10psi with every 1k of rpm.
    Now... what weight oil is he running? NOT that it matters if he has started hearing a knock... but if he is hearing a knock...and he is continuing to drive it.... its going to be done.
    Larry (Popo8) Co-owner
    LTXtech.com
    The Wrench
    May 2009
    Chile
    1994 9C1 6SPD
    South Jersey
    Like popo said it can be anything.
    You need to start with the basics.
    Does he have enough oil?
    Are there any oil leaks?
    When was the last oil change?
    Is the oil pressure sender in working condition?
    ASE L1 Master Certified Tech's 9C1 T56. Yeah she's got a big butt. But watch her move it.
    R.I.P. Z8
    Apr 2012
    Mike
    96 Z28, 95 Roadmaster
    Conshohocken, PA
    If you're driving around without oil pressure then your bearings will be toast in a matter of seconds.
  5. The Following User Says Thank You to Catmaigne For This Post:
  6. #5
    Jul 2010
    Alabama
    If its no pressure you will hear the valvetrain. No valvetrain noise i would start with the sensor and if its not that then bearings are going and its just going to go downhill fast.
    Prev: 94 Formula V8 M6 - R.I.P. / 96 Trans Am WS6 M6 - Sold / 00 Firebird 3.8 M5 - Sold
    Current: 94 Camaro Z28 A4
    Jesse
  7. The Following User Says Thank You to Badbird_96 For This Post:
  8. #6
    Jan 2012
    oklahoma city,ok
    He says it stays at the line above zero while driving and it has no leaks
  9. #7
    up date asap... hopefully its a guage... like jesse said...but with "noise" beimg heard...i do t like the odds.
    LTXtech.com
  10. #8
    3.4L to LT1 Swapper
    Oct 2008
    Brian Meissen
    1994 Camaro "Red Alert"; 2022 Camaro LT1 RS
    New Haven, MI
    When you say "the line above 0" does that mean it's at the 1/4th tick mark or it's barely above 0? Makes all the world of difference. If it seemed low and then all the sudden dropped to 0, I would expect that the oil pickup tube fell off and the oil pump is sucking air and/or the oil pump's drive gear got shredded. I had both happen to me while I was out cruising my car. Seemed kind of low and then when I went to head home I realized I had 0 oil pressure. Turns out the pickup tube fell off and for whatever reason I had brittle pieces of the oil pan gasket floating in my oil that got sucked up into the oil pump, jammed the impellers of the pump, and caused the cam to completely shred the oil pump drive gear.
    - Brian Meissen -
    "Magic Man" - LTxTech
  11. #9
    Mar 2013
    (had) 1995 chevy camaro z28 lt1 (had) 2006 GTO (had) 2012 chevy cruze 1.4L (current)
    Midwest City, Oklahoma
    Mar 2013
    Here is the sound it is making everyone let me know what you think and the car is sitting for the next couple of weeks till further investigation lol
