Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 22
Thread: Oil Pan
  1. #11
    Johnny
    1994 formula A4
    Henderson, TN
    Quote Originally Posted by Camaro96 View Post
    Sorry, if you have high mileage on your engine ( 1,000.000) miles I would recommend changing your oil pump. While you have the oil pan off. Its cheap ins to preserve your engine from bearing damage do to lack of oil.
    1,000? or 1,000,000?
    thats a big jump
    lol
  2. The Following User Says Thank You to fullforce For This Post:
  3. #12
    Sep 2014
    Joel
    Colorado
    thats a big jump
    lol
    One hundred thousand miles plus
  4. #13
    Dec 2013
    SoCal
    OP
    you found "gunk" on front of pan. IDK what it was but the note about replacing oil pump may apply more if whatever that gunk was, especially if the PU screen was clogged with some crap, also got sucked up inside oil pump.
    You could just open the pump up and inspect/clean and re-use if it checks out. Many put in the GM white spring (HP) in a stock pump
    I would get a 1 piece oil pump drive shaft regardless if you still have the stock one with plastic collar and are doing a cam swap
    96 BBB 383/T56
  5. The Following User Says Thank You to BALLSS For This Post:
  6. #14
    I'm that asshole over here using oil pumps with 250k miles on them and not having an issue, but what do I know?. if the motor had oiling issues, then maybe, MAYBE I would replace the pump. but there's nothing really to go wrong with the pump itself. stock pumps are fine.
    JB weld pickup tube on so it doesn't fall off
    GM white high pressure spring
    Melling 1 piece steel oil pump drive and done.
    Those parts will cost you about $30, and guess what, it's what we run in everything. @Ltconvert oil pump is a white spring stocker with 150k on it......and Karl Ellwein put it right in the 383 with nary a hesitation.
  7. The Following User Says Thank You to SSlowBoat For This Post:
  8. #15
    The FABRICATOR!
    southern illinois
    I've had good luck with these. The pickup comes welded to the pump. Drive with steel sleeve and mounting stud included.
    $50
    https://m.summitracing.com/parts/ses-3-60-08-003
  9. The Following User Says Thank You to firebird_1995 For This Post:
  10. #16
    Feb 2014
    1995 Mystic z28
    Lots to address here so I'll do my best.
    1st, I think the gunk in the pan was old oil and some road crud that had sat in the seam at the front of the timing cover. It was limited just to the front.
    Car had just hit 100k and never had any oil issues whatsoever.
    I hadn't planned on changing or modifying the oil pump. I'm running out of funds rapidly on this cam swap and hiding shitbon credit cards to mask the true cost.
    95 Mystic Z28, 17x9 FR, 17x11 RR ZR-1's, Pacesetter LT's and Y-pipe, Borla adjustable, Moroso CAI, 2800 Stall, AC Delete, and Cracked Dash/broken lid Mod.
  11. The Following User Says Thank You to donfrye For This Post:
  12. #17
    Johnny
    1994 formula A4
    Henderson, TN
    Lol
  13. #18
    Sep 2014
    Joel
    Colorado
    Quote Originally Posted by donfrye View Post
    That's understandable. The thought on the oil pump was erroring on the side of caution. I have scene a lot of premature engine failures do to oil pump performance. Looks like others have ran them for couple hundred thousand miles and not had issues. I was giving advice on wanting your cam swap to be with out a problem arising.
    Congrats on the cam upgrade hope you enjoy it.
  14. #19
    just get a white spring and 1 piece drive. it's cheap insurance
  15. #20
    Feb 2014
    1995 Mystic z28
    I'm not being a lazy ass but seriously have no idea where to obtain the spring and drive. Is that something Summit or Rockauto would have? I've only seen the full pump unit during my (mis) adventures.
