Page 31 of 82 FirstFirst ... 212728293031323334354181 ... LastLast
Results 301 to 310 of 820
  1. #301
    Ill sell u the one on the camaro if u wanna come remove it.
    OWNER/ADMIN
    ill message u, i cant remember if we looked to see if it was bent or not. i know your tunnel brace/ds loop was. was the camaro a full length or short?
  2. #302
    Ill sell u the one on the ta... but that wont be till after the 9" and ta from the camaro get swapped over. Def not b4 dyno day
    OWNER/ADMIN
  3. The Following User Says Thank You to popo8 For This Post:
  4. #303
    The camaro one im keepimg with the 9", its a long one. The ta one is a shorty with ds loop.
    OWNER/ADMIN
  5. The Following User Says Thank You to popo8 For This Post:
  6. #304
    ahhh no problem
  7. #305
    @Flyinz thanks for the lcas man.
  8. #306
    1994 Chevy Camaro z28
    IL
    Not a problem!
    94' Z -383 LTx, AI TFS 215cc heads/C/I
    S60 rear
    Stepped Hedman Hustlers an a Monoblade TB
  9. The Following User Says Thank You to Flyinz For This Post:
  10. #307
    Did change o2 sensor, old one was loose. Didn't get to start her though. Tomorrow after work I'm going over to reinstall wideband in @Ltconvert camaro and get a log of that for Jeff to calm down how ungodly fat it is. Then change my oil and go for another ride to put miles on motor and burp coolant
  11. The Following 2 Users Say Thank You to SSlowBoat For This Post:
  12. #308
    Vibration is above 3k, clutch in or out, neutral etc, worse in throttle. Calms down a little in 4th. Replacing clutch disc and pressure plate. If it's still there I'm screwed if it's the t56
  13. #309
    It has to be something with either the pp being out of balance or something else. I was really tired and rushed the other night and didn't pay attention well enough. The vibration happens anytime over 3k rpm, when driving it's worse, but it's there stopped when revved clutch in or out in neutral atleast it kinda looks cool
  14. #310
    New clutch and ram steel alignment tool showed up, and picked up rear and some sheetmetal today. Thanks to @Ltconvert for clutch/trucking services, @Sahara54 and @95 blackbird for rear, and @kitt8090 for sheetmetal/general humor at his expense
  15. The Following 3 Users Say Thank You to SSlowBoat For This Post:
