Results 1 to 3 of 3
    Nov 2010
    NoName
    LT4 C4, LT1 CE
    Kansas City
    Default Comp Cams 875-16 short travel OE type lifters. Procharger bypass valve.
    14K miles on them. List for $225 new; asking $145 shipped.
    Competition Cams 875-16 lifters. From their site:
    When dealing with full travel lifters, certain engines respond better to a light pre-load because it recovers more quickly from any bad harmonics in the valve train. Others work better with a heavy pre-load because oil volume is reduced under the plunger, which increases stiffness. COMP Cams Reduced Travel Hydraulic Roller Lifters allow you to have the advantages of both light pre-load and reduced oil volume, producing the most stable and highest revving hydraulic lifter available.
    Bypass valve has never been installed. $225 new.....$125 shipped in the lower 48OBO. P#AV008A-001
    Take to extremes and DOMINATE!
    Mark
    Altoona, PA
    @Fastbird not sure if these lifters would work for your buddy.
    Sent from my iPad using Tapatalk
    Long Live the Opti
    Sean
    1999 Twin Turbo Corvette
    Fort Wayne, IN
    @1QUICKZ28 thanks for the heads up but I think there's more misgivings going on with the motor. It's getting ready to be pulled and gone through.
