Page 4 of 7 FirstFirst 1234567 LastLast
Results 31 to 40 of 70
  1. #31
    This is the pic that it looked bent in...
    Sent from my SM-G900P using Tapatalk
    that's not a fork, that's the pushrod for the slave, which is being replaced
  2. #32
    Quote Originally Posted by BALLSS View Post
    what TQ did you do for PP bolts when you put the clutch in?
    45, arp pp bolts
  3. #33
    Yeah.. but thats what i was refn 2.
  4. The Following User Says Thank You to popo8 For This Post:
  5. #34
    Johnny
    1994 formula A4
    Henderson, TN
    @popo8 that picture does look bent.
    I had the same thing happen to my last car, Or at least very similar.
    Make a long story short, It was the first time I had pulled a t56 from a Lt1 and I didnt pull the fork out before trying to remove the transmission, I was prying on it and must have bent the fork slightly before I realized the fork had to removed to pull the trans.
    I didnt think I bent it but when I put everything back together the fork was touching the pressure plate if I pushed the clutch down all the way.
    I also thought my pushrod was suddenly to long but if I remember correctly I made a shorter one and it still contacted because the slave cylinder adjusts itself?
    Kinda like when your brake pads wear down the piston just comes out a little farther to make up for the difference in thickness if that makes any sense.
  6. #35
    the slave pushrod that pushes the fork is bent, I don't know if it was bent before this issue, but with the way the rest of this car is, I'll strongly assume it was. it is being replaced with new hydros/pushrod. the actual clutch release fork that grabs the throw out does not appear bent, and I can't afford a new fork ($200 yikes) before dyno day to test that theory.
    if anyone has a good clutch fork for less than the blood of my first born, and can get it to me by Friday this week, pm me.
  7. #36
    Johnny
    1994 formula A4
    Henderson, TN
    Can you tell if the fork was hitting the backside of the pressure plate?
  8. #37
    oh yeah
    not my pic, and mine isn't nearly as gouged, but looks the same on the edge, and can see the two contact points on the fork where.
  9. #38
    Johnny
    1994 formula A4
    Henderson, TN
    Yep that's exactly how mine looked, not that bad though either. I don't remember if I bent the fork back or if I just grinded it out a little more but I didn't purchase another fork.
  10. The Following User Says Thank You to fullforce For This Post:
  11. #39
    I'm gonna grind some off the pivot tee
  12. #40
    well zoom sucks. they won't warranty the pressure plate that is 2/10" thicker on the mounting pads than the old one, said handle it thru summit. summit said they may not honor warranty since pp is damaged.
    anyone used competition clutch
