Page 54 of 76 FirstFirst ... 44450515253545556575864 ... LastLast
Results 531 to 540 of 752
  1. #531
    The FABRICATOR!
    southern illinois
    Your timing set doesn't have multiple crank key ways cut for different advance/retard cam timing by chance does it?
  2. The Following User Says Thank You to firebird_1995 For This Post:
  3. #532
    The Nitrous Outlet Junkie
    Apr 2010
    Troy
    1994 Firebird Formula
    moore, ok (south okc)
    I'll be checking once I get the motor back
    But I don't think so.
  4. #533
    The FABRICATOR!
    southern illinois
    It's pretty hard to screw up installing a timing set really. Dot to dot is the #6 tdc position but it's the easiest to make sure they're lined up correctly. I'm afraid I would have to question the accuracy of their degreeing method before I would tear it apart. About the only other way it could have been screwed up is if there was no dowel on the cam and you put the cam gear on 120 or 240 off.
  5. The Following 2 Users Say Thank You to firebird_1995 For This Post:
  6. #534
    Apr 2010
    Troy
    exactly what i thought
  7. #535
    Quote Originally Posted by thanhtt147845 View Post
    Bên bạn có bán nhiệt kế điện t không cái ny mình đang cần
    @meissen
    OWNER/ADMIN
  8. The Following User Says Thank You to popo8 For This Post:
  9. #536
    Apr 2010
    Troy
    What is that?
    Sent from my SM-N910T using Tapatalk
  10. #537
    Nov 2011
    Marc
    1995 Formula
    magnolia, DE
    Stoopid spammers
    Sent from my A621BL using Tapatalk
    1995 FORMULA M6
  11. The Following User Says Thank You to 95 blackbird For This Post:
  12. #538
    Apr 2010
    Troy
    Well I am going to work on the motor when I get it back .... but on another subject for the time being .... I measured the drive shaft I got with the th400 and it's 44 1/4 eye 2 eye, total length 46.
    With a th400 short tail shaft and stock rear axle is that length sound right?
  13. #539
    Apr 2010
    Troy
    well a much needed update ... got a cam ordered from Lloyd Elliott @NightTrain66
    235/247 .579/.600 @112 lsa
    the cam that was in there was not going to do good with nitrous so he said that this will be much happier in there
    so looks like about 3 weeks or so i am hoping to get this thing back together and running
  14. The Following User Says Thank You to zooguy For This Post:
  15. #540
    Quote Originally Posted by zooguy View Post
    Did u figure out ur NO START issue?
    OWNER/ADMIN
