Results 471 to 480 of 1214
Thread: Project Rainbow Unicorn 2013
09-01-2014, 02:29 PM #471
The block bore was cleaned up and measured, sorry. That was after I took apart the motor I bought, local machine shop did that for me.
I am gonna take all the pistons to work and steam clean them then see what we have. The pitting you see is on the top ring, so IDK if thats dirt or what, but the tops of the pistons and the bores themselves looked great.Correlation does not imply causation.
09-01-2014, 02:49 PM #472The FABRICATOR!
- Jul 2011
- 1985 Monte Carlo SS
- southern illinois
- 7,164
What kind of oil pump you running? Standard volume, high volume, high pressure?
09-01-2014, 02:55 PM #473
09-01-2014, 03:00 PM #474The FABRICATOR!
- Jul 2011
- southern illinois
- 7,164
What's the looser bearing tolerances for when using a hv oil pump?
09-01-2014, 03:02 PM #475
09-01-2014, 03:18 PM #476VIP Member
- Apr 2011
- KYLE
- 95 MQBM Z28
- davison michigan
- 3,874
How's the lifter bores look that had that bad lobes?
09-01-2014, 03:25 PM #477
09-01-2014, 05:22 PM #478
LTXTech Sponsor
- Sep 2010
- Red Oak Tx
- 541
be sure to clean EVERYTHING that touched oil (valve covers, bottom of intake, oil pana nd pickup, timing cover, etc, etc). The metal missing from the cam lobes went all thru everything and in a perfect scenario was ALL cught by the filter but in the real world it was not.
Lloyd
09-01-2014, 05:27 PM #479Xtreme Member
- Apr 2010
- Brian DeLuca
- 1997 Trans Am WS6
- Piscataway, NJ
- 1,297
09-01-2014, 08:38 PM #480
LTXTech Sponsor
- Sep 2010
- Red Oak Tx
- 541
If it is open to head bolt hole make sure it is not open on other side of that hol to other port (cylinders 1/3, 5/7, etc). If it is connecting two ports that head bolt will need to be sleeved (use .502" guide reemer to enlarge the hole then install .500" brass tubing with loctite).
If it is just open to that hole it is just cosmetic as the boost will not go past the thread/sealant down into block or past the stud/nut on top either.
Was there anything different with that cylinder compared to the rest?
Lloyd
