Fastbird
Results 1 to 10 of 10
    Default can a loose dipstick cause the car to smell of oil?
    tonight i drove about 200 miles back from a car meet (super coupe shootout.. i used to own one and still know a lot of people in the club) and my car was smelling of oil. i found that the dipstick was not seated tightly on the tube and even now that i'm at home i had to kind of finegle it to get it to stay on there even with the car off. i'm thinking maybe the gasket on the dipstick tube is warn out? anyway can the fact the dipstick was not seated tightly on the tube (was sticking out maybe 1/2 an inch?) cause some oil to leak out and induce an oil smell? i have fixed all the major oil leaks within the last 2 years (intake manifold gasket, valve cover gaskets oil pan gasket) and didn't see any oil on the ground anywhere and i am not low at all.
    1995 Black Trans Am LT1/4L60E 14.48@96mph
    Mods: 17" Corvette GS replicas, K&N panel, MSD wires, NGK iridium plugs, Ram Air box and hood 3.42 gears
    1996 Camaro Z28, 1994 Trans Am GT, 1985/1996 Corvette CLONE
    sure, especially if it manages to work its way up the tube.... are you boosted???
    my 3 little angels
    Jan 2009
    charlotte,nc
    i can see it giving you the smell even without leaking any oil out
    JASON.C '97'm6,pro 5.0,k&ncai,bbk52mm w/bypass,magnaflow cats,flowmaster c/back,strano springs,kyb agx shocks, lca relocate brackets,hounds tooth 30th interior,70k
    when is the last time you were under your car.... just cuz you dont see spots, dont mean you dont have the leaks.....
    IE a leak that is small enough to hit your exhaust and burn will never leave a spot, but will stink of oil......
    Big Papi
    2015 Fusion Titanium AWD
    Moscow Mills Mo
    Blog Entries
    1
    yea
    LTX Jedi Master
    Feb 2009
    Elwood,Illinois
    Been there done that. finding oil leaks on these are NOT fun.
    LT1, M6, CC306 cam, Comp 918 springs, Hardened pushrods,Ported TB, TB Bypass, Descreened MAF, 4:10 Gear, pacesetter LTs, custom exhaust, Some Suspension Upgrades...
    Near future: LE2 package
    Its my BIGGEST pet peev..... I HATE OIL LEAKS....... HATE EM!!!!!!
    i might still have some small leaks but the major ones got fixed. in fact i think i did see a small spot on the ground but i think it was back further than the engine. but the dipstick was definately not seated right last night when i checked it.
    *edit* i had a brain fart last night. i was tired and not really thinking. i saw the big red dipstick handle sticking out and for some reason thought engine.... um no that would be the transmission dipstick that i saw popped out. the oil dipstick was fine.
    any idea why my trans dipstick keeps popping out? even with the car off it seems like it is barely on there and going over a decent sized bump is probably what caused it to come loose. maybe i smelt trans fluid instead but i thought it was oil.
  9. #9
    Feb 2009
    sioux city, IA
    Quote Originally Posted by BLK95TA View Post
    think with your dipstick jimmy . maybe check the fluid? could have too much?
    1994 T\A, BBK shorties,CAI, cutout, full exhaust,MSD wires, 160* t-stat, 3.73s, cc503-1.6rr's-lunati lifters-stock pushrods FTW
  10. #10
    my 3 little angels
    Jan 2009
    charlotte,nc
    make sure the end of it isnt bent or anything...dont they have some kind of o-ring or something near the handle?check that
