Thread: computer question
08-23-2009, 04:19 PM #1
computer question
I have a 94 OBD1 LT1 computer with a 97 wiring harness, when i try to plug in with a diagnostic machine it will not communicate. I've tried 2 different kinds of machines, and both do the same thing. they light up, say trying to link, then failure. Anyone know what might be wrong? could my computer be bad?
08-23-2009, 08:10 PM #2
Try checking your cigarete lighter, if the fuse is blown, you will not be able to communicate with your pcm.
tia
andy schuck94 T/A M6, AS&M headers, high flow cat, hooker aeorchamber catback, MadZ tune, k&n cai, 3.73 gears, 02 Z06 rims, umi lower control arms, taylor 8mm plug wires, descreened maf,
08-24-2009, 04:39 PM #3
ya, i thought of that but its getting power to the connector, just always failing to communicate. I'm sending my computer out to pcmforless to have it checked out.
08-24-2009, 08:07 PM #4
09-05-2009, 09:22 AM #5
PCM
SEND IT TO ION AT MADTUNER.COM HE WILL TAKE CARE OF YOU...
UNDER CONSTRUCTION! 1996 Camaro Z-28 6spd, cc306 cam, 1.6rr, MSD ignition and 2-step, all bolt on's, LE2 heads, 58mm intake and TB, 3.73 gears, CSR ewp. and much more.
09-10-2009, 04:41 PM #6
guys!! anyone out there. Im doing a basic cam swapp with a cc306.could i fire it up and still use my car after or do i need a computer programming right away. as soon as im dome with my cam swapp. ohh its a lt1.
10-01-2009, 09:02 AM #7
