Results 1 to 7 of 7
09-14-2008, 04:12 PM #1
weird problem after a/c compressor R/R
ok guys, i have a weird problem. Today i removed and replaced my a/c compressor with a new used one. The system has not yet been charged. Here is the problem. I refilled the radiator and started the car, waited for the t-stat to open up for circulation and put some more coolant in the Rad. I then put the cap on and continued to let it idle. Temps were ok and everything seemed okay. Then i heard water pouring. Looked in the engine bay and the coolant resivour was spewing. I opened the cap, there was no pressure, looked inside and could see no water. Also i noticed when i revved the engine a little bit the top coolant hose constricted. What the hell is going on? any help is much apreciated
1994 Camaro Z/28 Hardtop
Moroso CAI, Pacesetter LT's, !EGR, !AIR, 160* t-stat, 3.73's, MadZ28 Tune.
09-14-2008, 04:22 PM #2
anyone??
09-14-2008, 04:23 PM #3
09-14-2008, 04:34 PM #4
i thought that too...i couldn't get my bleed screw loose, so i just left the cap off...up buch of bubbles came up. but when it was done bubbling i but the cap back on and the same prob.
09-14-2008, 06:57 PM #5
Sounds like you got some major air pockets, the bleed screws are important.
Reverse flow = your going to need to drive it to even get all the air out. Bleed it as best you can, keep it from overheating and then take it for a ride to get the rest out.Nick
09-14-2008, 07:55 PM #6
09-14-2008, 09:58 PM #7
i did take it for a lil drive...it didnt overheat any, but the overflow resivoir did overflow..lol. Like i said i tried to loosen the bleeder screw, but it was froze. I put some PB blaster on it and im letting it sit over night.
