+ Reply to Thread
Page 3 of 3
FirstFirst 1 2 3
Results 21 to 24 of 24
Thread: My 1st LTX Shootout Mod
Threaded View
    Looks good man. Does the heater work ok with out using the heater valve? I haven't run my lines yet for the heater. I just capped them off at the pump. Did you ever make it to a tnt? Curious to see what it runs. My local strip opens tonight but it's going to rain.
    85 Trans am WS6 LT1
    madz28 tune,Custom CAI,Headers,Hooker catback,3.23 ls1 rear
    http://i306.photobucket.com/albums/n...5transam-1.jpg
    95 Ram Air Trans am
    The heater seems to work ok without the valve. I just used the whole hose assembly from the 94. It may blow to much hot air into the cabin in the summer, but we will worry about that later. I have made it to the track a couple time and it runs pretty good. My best has been a 13.49@103 with a 2.0x 60ft. I am pretty happy with that with so few mods on street tires and a 2.73:1 rear gear. I will be dropping it off at the body shop next week and ordering up a set of drag radials for the Shootout. Hope to see yours sometime.
    -David-
    1985 Z28 LT1/4L60e
    2000 Z28 LS1/M6
    On my setup I just got a few feet of 5/8" and 3/4"(might have been 1/2" and 5/8") heater hoses then ran them directly to the heater core. I ran the hoses over the top of the engine. The interior doesn't get warm at all as long as you have the heater switch set all the way to cold.
    Heater valves are just another thing that can break. I've had two of them break in the past. Plus, I think its a good thing to have coolant circulating through the heater core rather than it sitting and causing clogs.
    -Matt-
    1986 Trans Am - LT1, 4L60E, 3600 RPM Stall, 373's, C5 Z06 Front Brakes, WS7 Swaybars, Spohn SFC's, 4th Gen Dash, LS1 Plastic Gas Tank, 17x9 Black ZR1's
    Body work progress pics.
    The swap album so far has been updated.
    http://s206.photobucket.com/albums/b...immy/85%20Z28/
    -David-
    1985 Z28 LT1/4L60e
    2000 Z28 LS1/M6
+ Reply to Thread
