Page 4 of 4 FirstFirst 1234
Results 31 to 34 of 34
  1. #31
    @SSlowBoat
    I took a quick measurement. When I can get under the car again I'm sure I could adjust the plastic section and move the whole filter down to get somthing longer on there.
  2. The Following 2 Users Say Thank You to anniversaryss For This Post:
  3. #32
    Apr 2012
    Mike
    96 Z28, 95 Roadmaster
    Conshohocken, PA
    What brand of filter are you running at the moment? CFM of the filter media is equally as important as size when shopping for these. Popular K&N stuff uses a very restrictive media. The Spectre, AFe, and other diesel stuff moves way more CFM per square inch of media (and also puts more particulate into your motor, but that shouldn't matter much unless you live down a dirt road). I'm currently running the biggest Spectre from the parts store which seems to work and was cheap, but I also made a bracket to prevent the top button from getting sucked in.
  4. The Following 2 Users Say Thank You to Catmaigne For This Post:
  5. #33
    @Catmaigne
    Whatever the filter is that comes with the kit.
  6. The Following 2 Users Say Thank You to anniversaryss For This Post:
  7. #34
    Currently street tuning I have seen 14-15 psi. Up to 18° and seems good
    I changed to a larger filter and ks7 knock sensor. Getting some gains on timing and afr changes.
  8. The Following 2 Users Say Thank You to anniversaryss For This Post:
