Results 1 to 4 of 4
Thread: Auto pedals
11-22-2021, 07:17 PM #1Xtreme Member
- Sep 2012
- Chris P. Bacon
- 1994 Firebird Formula
- Lansing MI
- 1,467
Auto pedals
Looking for a set of auto pedals that will work in a 94 fbody. I also have a hole from where the master cylinder went through the firewall, so of someone is parting out a car i would buy whatever fills that hole.
'94 Formula 6spd
03-14-2022, 02:11 PM #2Xtreme Member
- Sep 2012
- Chris P. Bacon
- Lansing MI
- 1,467
Bump
'94 Formula 6spd
03-15-2022, 10:08 AM #3Xtreme Member
- 7,270
03-15-2022, 12:01 PM #4LTx Guru
Ancient history, but I sold my T56 stuff to someone for a conversion. He was supposed to send me his A4 pedals. His shop was dragging their feet, didnt have the pedals when we needed them. My shop was able to remove the clutch pedal from the manual trans assembly. Then they welded a wider steel piece on the manual trans brake pedal so it would support a stock A4 rubber pedal pad.
Used the master cyl hole in the firewall as a pass-thru for the braided SS line for the dash mounted mechanical oil pressure gauge. Sealed up around the hole.SOLD - GONE TO A (VERY) GOOD HOME ! - 94 Formula A3+1: 381ci forged stroker - Callies Stealth, Oliver 5.85 billet rods, BME nitrous pistons / CNC LT4 heads / CC solid roller / TH400+GearVendors OD / 4.11 Strange 12-bolt / 300-shot N2O / Spohn Suspension / roll bar / MoTeC M48 Pro engine management system /a few other odds 'n ends.
