Page 3 of 3 FirstFirst 123
Results 21 to 24 of 24
  1. #21
    Mar 2015
    Mike Storm "Stormy"
    1995 Trans Am
    Washington
    Blog Entries
    1
    Yes you can. Im pretty sure that flat rod will slide out it may be still connected to the lock. You might have to wiggle it free. If you get what I'm saying. The three bolts on the bottom latch.
  2. #22
    Do you see the silver tipped, flat blade sticking out of the bottom of the latch? That is the blade the key cylinder rotates to release the latch. Try turning it with a pliers. That may release the latch. If the hole in the latch is worn, allowing the blade to spin freely, without releasing the latch, try inserting a flat screwdriver along the side of the silver tipped blade, and try rotating the screwdriver.
    If that fails, removing the three bolts should free the latch assembly from the sheet metal it mounts to. You may need to pull the latch forward to get it off the silver tipped blade. Then lift the hatch and it should raise with the latch mechanism still attached to the hatch. Then you can figure out how to undo the latch mechanism while standing outside the back of the car.
  3. #23
    Sep 2012
    Chris P. Bacon
    1994 Firebird Formula
    Lansing MI
    Are you saying to pull that rod out a little bit then try turning it? I can try that tonight.
    When I tried turning the rod it was definitely still hooked to something. I was afraid that twisting much harder than you would a key that I could mess it up more. I think pulling the whole latch assembly out will make it easier to mess with.
    I grabbed that by hand and it would not turn. With pliers it would not turn either. I can try really twisting but I definitely twisted harder than you would a key.
    The rod seems a little crooked to me, like it's not sticking straight out. I wonder if something hit it causing it to get jammed? From what I remember when it worked you only turn the key 90 or 180 degrees before it unlatches. The key now spins at least 3/4 of the way around before you feel anything, and still doesn't unlatch.
    I will unbolt the latch striker from the hatch so I can open the hatch, then worry about getting the latch and key cylinder free. I imagine those parts wouldn't be too bad to find.
    '94 Formula 6spd
  4. #24
    Mar 2015
    Mike Storm "Stormy"
    1995 Trans Am
    Washington
    Blog Entries
    1
    Yeah unbolt that sucker then deal with it.
  5. The Following User Says Thank You to Stormyweather For This Post:
