Results 11 to 20 of 49
10-23-2019, 10:06 AM #11LTx Guru
You can’t flash the codes on a 95 by shorting the DLC pins. 1993 was the last year that worked. You need an OBD-1 scanner. Connect using the correct 12-pin —> 16-pin adapter, or jumper the pins from the DLC connector to the scanner connector:
http://shbox.com/1/xraycable.jpg
10-23-2019, 08:26 PM #12
You think this would work For the codes ? I dont wanna short something out though . .
10-24-2019, 02:26 PM #13Xtreme Member
- Mar 2015
- Mike Storm "Stormy"
- 1995 Trans Am
- Washington
- 1,020
- Blog Entries
- 1
GaryDoug' s. Scan9495 works great. No short pin.
10-24-2019, 05:03 PM #14Xtreme Member
- 7,269
10-25-2019, 02:16 PM #15
10-25-2019, 05:08 PM #16Xtreme Member
- Mar 2015
- 1995 Trans Am
- Washington
- 1,020
- Blog Entries
- 1
But you can program your key fob.
10-30-2019, 05:41 AM #17
Sorry for the late reply, wasn't able to acces the site for some reason. I haven't been able to say for sure if its fixed, however, I did go under it and repaired 2 ground wires. Small one from the starter looked almost as if a squirrel had nibbled on it a little. The large wire from either the battery or alternator to the block was fraying a bit so I replaced it. No issues since, but I haven't had it on a long enough trip to be 100% sure yet.
Sent from my SM-G965U using TapatalkMATT
11-14-2019, 09:24 AM #18
Nice I havent had much time to work on it but will definitely start there . I ended up buying the Bosch 1300 scanner. Just havent been able to diagnose while the problem happens . But i do have a Quad Driver 2 Bad that shows up from startup to shutdown any ideas what this does?
11-14-2019, 01:10 PM #19LTx Guru
Is the code DTC 27? That was the Quad Driver #2 code up until 1993. After that, it's for the EGR vacuum solenoid.
11-14-2019, 04:34 PM #20
Could that be the cause for my shutoff problem.? I also noticed that the voltage starts dropping as the car gets to normL temp once the voltage drops to a little under half thats when it starts acting up .
