Page 5 of 5 FirstFirst 12345
Results 41 to 49 of 49
  1. #41
    Oct 2019
    Ulises
    Yepez
    So I Replaced my ignitikn switch last night hooked up the scanner today Nd my quad driver 2 reads ok now on my 93 z . . Would that be a reason for my shutoff? There hasnt been a hot day so wont be able to tell if problem is gone yet.
  2. #42
    Apparently you dont believe me when I tell you there is no quad driver.
  3. The Following User Says Thank You to Injuneer For This Post:
  4. #43
    Mar 2015
    Mike Storm "Stormy"
    1995 Trans Am
    Washington
    Blog Entries
    1
    Quote Originally Posted by Uyepz28 View Post
    What year is the car? A 93 Or a 95?
    Sent from my HP Pro Slate 8 using Tapatalk
  5. #44
    The pcm is a 95. Has obd 2 plug but is obd 1 . Hard to find what pins to jump to get the flash codes .
  6. #45
    Mar 2015
    Mike Storm "Stormy"
    1995 Trans Am
    Washington
    Blog Entries
    1
    " Nd my quad driver 2 reads ok now on my 93 z " I'm confused. I now remember reading that. But. What is really going on? Maybe hes got a 95 z. I'll go back quiet.
  7. #46
    Oct 2019
    Ulises
    Yepez
    Sorry about the confusion my mistake on the 93 95 thing was i was buying it when i was told it was a 95 . When i finally met the guy it turned out to be a 93 . So now i think im pretty close to solving the problem though.
    The car stuttered on me today while coming to a stop . I didnt shut it off when i got to the driveway hooked up the obd one and low res code popped out. Now i have 2 codes to work on but quad driver 2 is ok now .
  8. #47
    Are you serious? The FIRST question I asked you, in response to your FIRST post was “What year is the PCM.” You said it was a 95 and went into the explanation about how it has an OBD-2 plug, but the PCM is OBD-1. And at no time over the 6 weeks I've been helping you, pointing out the differences between the 93 and the 94/95 computers, you never bothered to tell me you discovered it’s a 93? SMH
    Good luck.....
  9. The Following User Says Thank You to Injuneer For This Post:
  10. #48
    Oct 2019
    Ulises
    Yepez
    Sorry man. .my apologies. Ill try to figure it out myself now but you been a great help . Thank you . Happy holidays. And Ill still keep you guys updated as i throw parts into it untill the issue goes away.
  11. #49
    Oct 2019
    Ulises
    Yepez
    Cool So i think i figured it out was my opti and opti harness that were taking a shit. Thanks for all the help Guys.
