Results 11 to 20 of 24
Thread: Fuel leak
06-29-2019, 08:23 PM #11Xtreme Member
- 7,270
Supporting Memberi would just make my own. the fittings and line is cheap, and the tool will pay for itself short term
or try calling hawks. theyve got me some weird oddball stuff more than once
Sent from my SM-G975U using Tapatalk2021 Charger Scat 392
06-30-2019, 03:42 PM #12LTx Guru
No luck on the old fuel lines. So damn hot here I thought I was going to have a heat stroke in the attic. Actually found the corrugated plastic cover with labels for the fuel lines, but no lines. Also reminded me I have a new/unused set of Hooker Super Comp long tubes in the attic I need to get rid of.
Try as many of the GM online parts dealers as you can. I saw a post in the last month or two from someone that claimed he found a dealer with an OEM Opti collecting dust on a shelf. Dealer was happy to get rid of it.
Another alternate is -6AN braided S/S lines. You can buy fittings w/ GM quick connects on one end and -6AN on the other. Supply is 3/8, return is 5/16. You could probably find ready-made -6AN FUEL lines in 3-foot or 4-foot lengths (not sure which is required). Not cheap but pretty much indestructible. I never liked the stock nylon tubing for anything other than stock setup, with the corrugated plastic tube covering, and a working ring clip attached to the throttle body linkage cover to keep the bundle off the exhaust.
http://www.getfast1.com/RUS-640853-P...-LS1_p_28.html
07-01-2019, 01:54 PM #13Xtreme Member
- Mar 2015
- Mike Storm "Stormy"
- 1995 Trans Am
- Washington
- 1,020
- Blog Entries
- 1
Thanks for looking, old man
Sent from my HP Pro Slate 8 using TapatalkLast edited by Stormyweather; 07-03-2019 at 12:00 PM.
07-02-2019, 05:46 PM #14Xtreme Member
- Mar 2015
- 1995 Trans Am
- Washington
- 1,020
- Blog Entries
- 1
Founds this
http://www.purechoicemotorsports.com...rod/prd360.htm
07-02-2019, 08:45 PM #15LTx Guru
That should work if they saY it does.... seems like the parts I described, except the connector hard line ends. The factory quick connects don't have the plastic clips (collar). You have to use a special tool to release the metal collar. But apparently the plastic clip style is interchangeable. The factory setup does use the plastic clip style at the inlet to the fuel filter.
07-03-2019, 07:45 AM #16LTX Master
- Aug 2013
- JB
- Atoka,TN
- 531
The Following User Says Thank You to Cathead For This Post:
07-03-2019, 12:10 PM #17Xtreme Member
- Mar 2015
- 1995 Trans Am
- Washington
- 1,020
- Blog Entries
- 1
Yes it looks like the plastic cup one is for ease of on and off. I think some more shopping around. It was a good price for all that though. I'd like to find a cleaner set up.
07-10-2019, 02:12 PM #18Xtreme Member
- Mar 2015
- 1995 Trans Am
- Washington
- 1,020
- Blog Entries
- 1
Found a pic on the home camera of the trail of gas. Ordered a used line from Hawks for now. Will let you know when I'm done.
08-29-2019, 01:50 PM #19Xtreme Member
- Mar 2015
- 1995 Trans Am
- Washington
- 1,020
- Blog Entries
- 1
Well it's fixed used a set from Hawks. Wasn't the best part but it worked. The hardest part was putting the inside fender well back. lineing up the old holes was a pita. Mostly a snap literally. Now on to replaceing o2s and injectors and plugs and wires still running rich. Not as neck snaping as it was.
08-29-2019, 02:15 PM #20LTx Guru
Tie the hoses up and make sure they aren’t resting on the AIR piping. If the AIR check valve leaks, the piping gets hot, the rubber elbow on the AIR piping melts and hot exhaust escapes.
When the car left the factory, there was a large diameter plastic spring clip that held the hoses, and mounted in a hole on the side of the plastic throttle linkage cover. If that's missing you can make one with a black nylon cable tie.
