Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: Fuel leak
    Mar 2015
    Mike Storm "Stormy"
    1995 Trans Am
    Washington
    Blog Entries
    1
    Default Fuel leak
    Well I have this leak on the return line engine side by the connection. Took a bit to find well with a jack took a min to find.
    Need a new hose or hoses. Any help with finding would be appreciated.
    Sent from my LG-G710 using Tapatalk
    If that is the 3-line nylon bundle that runs from inside the rocker panel near the driver’s door, to the hard lines for the fuel rails, the GM part # is 10258441. That's a ~$20 part. I looked at a couple GM online parts shop, and one showed “no longer available”, another showed it in stock.
    http://oemcats.com/shop/jake_sweeney...&search_mark=0
    Mar 2015
    Mike Storm "Stormy"
    1995 Trans Am
    Washington
    Blog Entries
    1
    Yeah its that it, the bundle is one part?
    Definitely includes supply and return, and I think the EVAP purge line.
  5. The Following User Says Thank You to Injuneer For This Post:
  6. #5
    Mar 2015
    Mike Storm "Stormy"
    1995 Trans Am
    Washington
    Blog Entries
    1
    Wow thank again.
  7. #6
    Mar 2015
    Mike Storm "Stormy"
    1995 Trans Am
    Washington
    Blog Entries
    1
    Ill call them tomorrow says out of stock online every where.
  8. #7
    Mar 2015
    Mike Storm "Stormy"
    1995 Trans Am
    Washington
    Blog Entries
    1
    Heh that's a Russian web site. They said they get about 50 calls a day looking for obsolete parts. And being a Russian site they can't do anything. Looks like E bay or Hawks. Unless someone on this site has any fuel line laying around that they would love to sell me. Help a brother out. I'm a old man in need of some help. And a Air Force Vet too.
  9. #8
    I'll look up in the attic over my garage. I have parts that were removed 19 years ago when we built the stroker, replaced with 100% braided SS -AN lines. Can’t specifically remember the lines.... but since I suspect I'm even older than you, my memory isn’t what is used to be
    I can’t look until tomorrow.
  10. The Following User Says Thank You to Injuneer For This Post:
  11. #9
    Mar 2015
    Mike Storm "Stormy"
    1995 Trans Am
    Washington
    Blog Entries
    1
    Lol cool
  12. #10
    Pr0jekt Turb0?
    Ryan
    1993 Camaro Z28
    Utica, NY + Jacksonville, FL
    I used to use this site in the past, can't hurt to try
    https://www.gmpartsdirect.com/oem-pa...emmis-10258441
    -Ryan
    93 Z28 M28
    Mod List
  13. The Following User Says Thank You to Z28pr0jekt For This Post:
