Results 1 to 2 of 2
Thread: 97 Formula RPM sensor code
12-30-2018, 09:46 PM #1Lurker
- Oct 2017
- SAM
- 2008 G8 GT 1999 Z28 6M Pewter Sold 15 Q50S
- High Point Nc
- 15
Looking at a car with an RPM sensor fault. Any info is appreciated on what it is and how it affects a car.
12-30-2018, 11:21 PM #2LTx Guru
What is the specific numerical code? RPM data is fed to the PCM by the optical cam position sensor in the Optispark distributor. The is a code for the high resolution pulse signal (P0372) and another for the low resolution pulse signal (P1371). Also one for an intermittent low res signal (P0323).
Is the engine running? Will not run with active P1372, will run with P0371.Last edited by Injuneer; 12-30-2018 at 11:25 PM.
