Results 11 to 20 of 33
Thread: Oil psi dropping
06-30-2018, 09:33 AM #11"The Rock"
06-30-2018, 10:39 AM #12Xtreme Member
- 7,269
Supporting MemberI've just jb welded all mine on and havent had one fall off
06-30-2018, 10:46 AM #13The Nitrous Outlet Junkie
- Apr 2010
- Troy
- 1994 Firebird Formula
- moore, ok (south okc)
- 3,274
06-30-2018, 10:56 AM #14Xtreme Member
- 7,269
06-30-2018, 12:50 PM #15LTx Guru
Don't they still make retainer clips that bolt to the tube and attach to two of the pump bolts? Used them a long time ago.
06-30-2018, 08:50 PM #16Xtreme Member
- 7,269
07-01-2018, 03:41 PM #17
the press on fit should hold but most realize they don't which is why tack weld is done. The casting and tube are not the same metal so if the weld is cold or does not cover a good portion of the seam it can crack at the weld and the pick up comes off
I have never heard anyone else using JB Weld until Tubby mentioned it. IDK how impervious it is to oil or internal engine heat
IDK if Melling makes a pump with a bolt on pick up for the LT1...been so long since I had a stock oil pump. Mine is tack welded96 BBB 383/T56
07-01-2018, 03:55 PM #18Xtreme Member
- 7,269
07-01-2018, 05:26 PM #19LTX Master
- Aug 2013
- JB
- Atoka,TN
- 531
07-01-2018, 05:32 PM #20The Nitrous Outlet Junkie
- Apr 2010
- Troy
- 3,274
Well here's my pickup tube fix ... now I shouldn't have any problems with it ever coming off again also while I had the pan off I took out the oil level sending unit and welded that guy should because it leaked a little bit
Sent from my SM-N950U using Tapatalk94 Formula "budget build" #thebeaterbird
