Results 1 to 10 of 12
Thread: Engine Harness Options
03-12-2018, 08:33 AM #1
Had to fix two small nicks in my injector harness over the weekend (somehow engine ran on 2 cyl per side) and realized how old/frail the harness is.
Any ideas or places to check out for getting basic universal harnesses? My setup is not like stock so do not want another factory harness to take apart.
If I could find pigtails with each connector made up already with ~5ft of wire, that would be perfect.
LS1 PCM, 24x setup.Correlation does not imply causation.
03-12-2018, 02:22 PM #2VIP Member
- Dec 2011
- Mark
- Altoona, PA
- 809
Here are some options.
https://www.psiconversion.com/produc.../HAR-1005.html
https://www.speedwaymotors.com/Speed...ess,46371.html
https://www.eficonnection.com/home/c...and-connectors
Sent from my iPhone using TapatalkStock bottom end, Impala head gaskets, Stock heads w/stage 2 port polish Comp beehive springs, Crane 1.6 RR's, Thunder Racing cam, Cloyes Billet True Roller TC, Long tubes, custom true dual 3" w/X-pipe, Ported intake with 58mm TB, 36lb injectors, PCMforless chip, Tick Performance stage 3 M6, Strange S60 4:10's True Trac 35 spline axles, MSD complete Ignition system, Summit electric water pump and a ton of other upgrades.
03-12-2018, 07:05 PM #3Long Live the Opti
03-12-2018, 07:43 PM #4
03-13-2018, 06:31 AM #5"The Rock"
03-13-2018, 07:29 AM #6
03-13-2018, 12:55 PM #7VIP Member
- Dec 2011
- Mark
- Altoona, PA
- 809
https://www.bp-automotive.com/
Forgot to add them on the list above.
03-13-2018, 04:35 PM #8Xtreme Member
- 7,249
Supporting Memberbp still does them. quoted me 750 for a new engine/trans harness with emissions deleted and ewp integrated in last week
Sent from my SM-N950U using Tapatalk2021 Charger Scat 392
03-17-2018, 06:17 PM #9LTX Master
- Nov 2008
- Enrique
- 93 Z28
- Houston/Clear Lake
- 615
I got a harness from BP and is was top notch. Fyi
03-19-2018, 07:16 AM #10
