Results 1 to 10 of 10
    Aug 2016
    Dan H
    1995 LT1 Caprice
    Default Engine knock - tore it open. Pix inside...
    Had a knock when hot, and only when hot. Pulled the engine and dug into it and didn't find anything that screams "bad bearing", but I did see that the center mains were polished to a mirror like shine. What do you all think?
    Rearmost cap has some weird horizontal scars.
    Cap 2:
    Cap 3:
    Cap 4 - has a gouge in it. You can also see the different color of the 'gray' bearing surface up by my thumb. The rest of it has been polished-off
    Front cap:
    Some of the rod bearings also had horizontal scars:
    All of the rod bearings also had these odd deposits on the bearing surface. Could not be wiped off. Not able to actually feel anything, though
    Cam lobes looked ok. This one looked a bit weird. Probably get it polished pre-install
    Anyway, if anyone wants to offer any ideas, I'm all ears. I don't want to do this again.
    I also noticed a lot of oil-scale on the tops of my pistons. I am going to get the heads checked out and make sure the valve seals are good.
    Johnny
    1994 formula A4
    Henderson, TN
    oil pressure drop when hot?
    Aug 2016
    Dan H
    1995 LT1 Caprice
    Eh, no more than normal. 28-32psi hot on average.
    Sep 2017
    Kyle Throckmorton
    1972 Corvette 1996 Corvette
    What does the crank look like on the journal surfaces? Any coolant leaks internally before? I know Dexcool will kill one fast if it gets in there. Did you check the oil for debris or metallic particles?
    Aug 2016
    Dan H
    1995 LT1 Caprice
    Quote Originally Posted by 72LT1 View Post
    Journals on the crank looked fresh from the machine shop. No coolant leaks. I cut open the filter and there were tee-tiny flecks of metal in there, which is what led me to pull the engine and tear into it. I also am suspect of the lifters as it appears that some of the external coating on the rollers has started to flake off. Yes, you can catch a nail on these defects. These are Crower 6630 lifters.
    Jan 2017
    David Mayer
    David
    That flaking off your lifters is probably what got embedded into your bearings causing those pits. My guess
    How did the skirts look on the pistons? Too much piston to wall clearance will also cause a "knock" piston slap
  7. The Following User Says Thank You to Daveyhouse For This Post:
  8. #7
    Aug 2016
    Dan H
    1995 LT1 Caprice
    Skirts looked practically brand new. There is some scuffing inside the cylinder bores, but nothing outlandish. Pin-to-piston clearance is within spec. Still have not seen anything that points to "well THERE'S the knocker..." which in itself, pisses me off. I'm glad I tore into it because those lifters would have eventually killed the cam and made for large, expensive problems - but that knock I was hearing sounded exactly like a rod. The cam is shot, however.
  9. #8
    Johnny
    1994 formula A4
    Henderson, TN
    Did you crank it with the belt off to make sure it wasnt something in the acc drive?
  10. #9
    Sep 2017
    Kyle Throckmorton
    Any updates on what you suspect or found? Did you contact Crowers and email them pictures of the lifters?
  11. #10
    Feb 2018
    That guy...
    1994 Trans Am
    Winchester, VA
    Man I would be angry if this were my engine, you are handling it much better than me.
    Sent from my N9560 using Tapatalk
