Page 1 of 4 1234 LastLast
Results 1 to 10 of 36
    Default 396 LT1 NA dyno results
    So after all the blood sweat and tears, the car finally made some decent numbers.
    heres the link let me know what you guys think.
    Jul 2013
    Alex Rauld
    1994 Trans Am GT
    480rwhp is pretty solid what's the setup? Hydraulic roller or solid? Heads?
    1994 Trans Am GT - HPS Ported Heads/Intake, LE Cam, FTI 3600, TP Built 4L60e, Moser 9" w/ 3.90's, BMR Suspension, Formato Tuned
    396 stroker
    AI custom Hyd roller cam
    AFR 210s
    10.5 compression
    Factory intake manifold ported
    24x torqhead swap
    6speed
    A/C power steering
    Runs on Cali 91 piss
    Oct 2014
    Justin
    1995 Formula
    Houston, TX
    Why only 10.5?
    95 Cyber Grey Formula
    396 M6
    LE 244/252 .636/.636 110
    LE 215cc Trickflows
    I first built the short block with the intentions of adding boost. Buuut life happens, you start popping out kids and the cash just isn’t there anymore. So you do what you can do, within the budget, to get decent compression and just go from there. Not to mention, pump gas is horrific out here in Cali. But even with compression on the lower end of the NA scale, I still think the motor performs very well. I can add plenty of timing without knocking.
    Jul 2013
    Alex Rauld
    1994 Trans Am GT
    Are those out of the box Afr 210s? If so race ready or competition port?
    They’re actually the older model AFR 1057s. But they’ve had light port work.
    Aug 2013
    JB
    Atoka,TN
    I have a similar setup but never dyno'd. I would love to make those numbers.
  9. #9
    Oct 2014
    Justin
    1995 Formula
    Houston, TX
    what are the cam specs?
    396 M6
    LE 215cc Trickflows
  10. #10
    Nov 2008
    Enrique
    93 Z28
    Houston/Clear Lake
    With that compression those are real good numbers!
