Results 1 to 7 of 7
Thread: injector Circuit breaker??
02-08-2018, 03:48 PM #1LTX Master
- Jun 2013
- Beaver
- 1994 camaro Z28
- KENTUCKY
- 600
Where is this located at??
BEAVER
02-08-2018, 07:30 PM #2LTx Guru
Just 7.5 amp fuses. #9 and #10 in the under hood box.
02-09-2018, 10:11 AM #3LTX Master
- Jun 2013
- Beaver
- 1994 camaro Z28
- KENTUCKY
- 600
Thanks
Sent from my SM-G930R6 using TapatalkBEAVER
02-09-2018, 07:31 PM #4LTX Master
- Jun 2013
- Beaver
- 1994 camaro Z28
- KENTUCKY
- 600
The fuse was good I got a code saying injector circuit breaker. So where else could I look
02-09-2018, 09:09 PM #5LTx Guru
Were BOTH fuses good?
DTC code 18 is NOT for "injector circuit BREAKER", its for "injector circuit". That means the voltage on one (or more) of the 8 injector circuits is not correct.
- Each injector connector should have 12 volts on the pink wire, with key on. Check with a volt meter.
- Each injector should have a resistance of ~12-16 ohms. Measure resistance across the 2 injector pins with an ohm meter, connector off the injector.
- The PCM supplies a ground to fire each injector. The best way to check this, with the engine running, is a noid light.
PCM/injector wiring diagram (94 is the same as 95):
http://shbox.com/1/1995_pcm3.jpgSOLD - GONE TO A (VERY) GOOD HOME ! - 94 Formula A3+1: 381ci forged stroker - Callies Stealth, Oliver 5.85 billet rods, BME nitrous pistons / CNC LT4 heads / CC solid roller / TH400+GearVendors OD / 4.11 Strange 12-bolt / 300-shot N2O / Spohn Suspension / roll bar / MoTeC M48 Pro engine management system /a few other odds 'n ends.
02-10-2018, 02:02 PM #6LTX Master
- Jun 2013
- Beaver
- 1994 camaro Z28
- KENTUCKY
- 600
03-03-2018, 06:30 PM #7LTX Master
- Jun 2013
- Beaver
- 1994 camaro Z28
- KENTUCKY
- 600
I got all problems fixed. I replaced the PCM and all is good. No codes no service engine light. Takes full better n idols better.
