Results 1 to 6 of 6
02-04-2018, 11:28 AM #1
Need help changing Cylinder #7 spark plug wire
Hello, I tried a search on this topic and got no results.
Im trying to replace a burnt plug wire, and its cylinder #7. Now, after driving onto rhino ramps I can get to the wire itself fairly easily, but theres this metal bracket holding the wire to the engine block between my exhaust manifold and the wire. I cant get the wire out of this bracket, whats the deal?
I actually broke the old wire in half trying to wiggle it out of there, so Ive been driving around on 7 cylinders for a couple days."I don't get it. I'm not exactly deaf and I've never given tire noise a second thought. So, I think the people that complain about them are: a) Suffering from hyperacusis b) Candy asses c) Still waiting to have their mufflers changed to the "real man" version" - HAHAHAHAHA quote from vmptuning on fordgt500.com
02-04-2018, 05:23 PM #2LTX Master
- Aug 2013
- JB
- Atoka,TN
- 531
It's been a very long time since I've had exhaust manifolds on my car so I can't remember the bracket your talking about but, is there a way you could take off the bracket to make the wire more manageable to remove and then replace?
Sent from my SAMSUNG-SM-G900A using TapatalkSame as everybody else...350 small block, double hump heads, 3/4 cam
02-04-2018, 06:57 PM #3LTx Guru
Going back 22 years on this one, but as I recall, there is a screw that holds the metal shield over the wire. It is possible to access the screw with stock manifolds. But it takes a lot of patience.
02-04-2018, 10:39 PM #4
Yep there's a small screw that holds the shield. It's not that difficult once you find the screw. And you just reminded me how much I hated working on the LT1 cars. I'm pretty sure I've dropped the entire drivetrain in less time than a plug wire swap took.
The Following User Says Thank You to AL 9C1 For This Post:
02-04-2018, 11:57 PM #5LTX Master
- Aug 2013
- JB
- Atoka,TN
- 531
I have a friend who was a mechanic and if I remember correctly, he told me that the book time on plugs and wires, for my 94 Camaro, called for 8 hours! He let me use one of their lifts and it took me 6 hours on my first time. It was a pain.
02-26-2018, 11:13 AM #6Lurker
- Feb 2018
- That guy...
- 1994 Trans Am
- Winchester, VA
- 68
