Results 1 to 10 of 15
Thread: 94 z28 camaro
01-21-2018, 05:05 PM #1Lurker
- Jan 2018
- steven rogers
- 1994 camaro z28 383 eagle crank,k/b performance piston bored 30 over,comp cam,ported heads
- 13
94 z28 camaro
Am new to this but am looking to rebuilt my z28 it has a real bad blow by so am looking to buy some some parts and could use some help with choosing the right parts for my build
01-21-2018, 08:16 PM #2Xtreme Member
- Apr 2012
- Cameron
- Dover, De
- 2,076
Formula Build Thread
01-22-2018, 09:11 AM #3LTx Guru
You're going to have to open it up and inspect the rings, pistons, and cylinder walls to determine the specific cause of the blowby.
01-23-2018, 07:51 PM #4Lurker
- Jan 2018
- steven rogers
- 13
its t56 has complete comp cam kit and ported heads with headers 3'stainless exhaust but ill have around 2500 to 3000 budget wish just looking to try get around 350 to 400 hp but the motor was suppose to have been spotless inside no ring wear what so ever and on my way home i started having optispark problem and now after i got it back running now i have a bad blowbye
01-24-2018, 12:28 AM #5Xtreme Member
- Apr 2012
- Cameron
- Dover, De
- 2,076
What injectors and if so was it tuned for them? Any info on who ported the heads and cam specs.
Sent from my iPhone using Tapatalk2012 Sierra - 5.3, Summit "Stage 1" Truck Cam
01-24-2018, 10:49 AM #6
Never take anyone's word on what they say the engine has in it or condition. You need to determine cause of blowby before you make any choices.
01-24-2018, 08:14 PM #7Xtreme Member
- 7,266
Supporting MemberI. can't. do. this. anymore. without. punctuation
01-25-2018, 09:25 PM #8
Didn't these things have issues with valve stem seals blowing by pretty bad? Either way I would do some compression testing before I go to far diagnosing.
01-25-2018, 10:44 PM #9Xtreme Member
- 7,266
Supporting Memberhow do you know you even have blow by? I thought we fried a heads cam boosted stock bottom end because I was getting puff puff puff out of the breather......
The Pcv valve was stuck.....I tore a whole car apart that was then down half a year for a pcv valve...
01-29-2018, 08:45 AM #10Lurker
- Jan 2018
- steven rogers
- 13
ok i drove the car the other day and found out that 3 of the roller rockers has jumped off and one of the push rods fell down in the head maybe thats what was causing the blow by and loss of power plus it is blowing oil out around the dip stick and front seal can that cause all them prob
