KeeAudio
    The Nitrous Outlet Junkie
    Apr 2010
    Troy
    1994 Firebird Formula
    bethany, ok (okc)
    Default Tail light not working correctly now
    Okay about 3 years ago when I was a daily driving the car the brake lights worked perfectly fine the car was parked for a couple of years for a new engine rebuild and dedicated drag racing build. So now the car is drivable again and the tail lights now are acting up everybody says to check my grounds and everything is good and tight I literally haven't changed or done anything so I don't know what's happened.
    The video shows what's going on
    94 Formula; sleeper/budget build - total invested so far $2777,
    best pass to date 11.902 @113.73 (forged shortblock coming soon)
    95 Formula, R.I.P (check you oil pump drive gear)
    Have you checked the sockets for corrosion? Seems like the bright filament for the brakes is still getting voltage without the brake pedal being pressed.
    94 Formula A3+1: 381ci forged stroker - Callies Stealth, Oliver 5.85 billet rods, BME nitrous pistons / CNC LT4 heads / Comp Cams solid roller / TH400+GearVendors OD / 4.11's/Strange 12-bolt / 300-shot (dry) N2O / Spohn Suspension / 6-pt roll bar /AutoMeter instrumentation / MoTeC M48 Pro engine management system /a few other odds 'n ends.
    Mar 2015
    Stormy
    1995 Trans Am
    Washington
    Yeah that was a deal with mine had to change everyone. Sockets where crap.
    1995 Trans Am - CAI - TB coolant bypass - Performance Muffler - Poly mounts - stock LT1/A4 - 13.3 1/4 - 1.9 60 foot , driven daily. .
    Johnny
    1994 formula A4
    Henderson, TN
    Dont buy the dorman ones, they are JUNK
    Apr 2010
    Troy
    bethany, ok (okc)
    what do I buy then?
    Johnny
    1994 formula A4
    Henderson, TN
    That's a good question, I got 1 from Dorman witch I am using now but had to basically destroy it to get it to fit. I wonder if the ls1 style sockets will fit?
    Jul 2013
    95 Firehawk
    Indiana
    LS1 sockets should fit. LS tail lights are always swapped into the LT cars, so should be the same.
    Apr 2010
    Troy
    bethany, ok (okc)
    But where can I find some good NEW pigtails/sockets for the tail lights?
    Mar 2015
    Stormy
    1995 Trans Am
    Washington
    I got some from rock auto. Got the high dollar ones. Use heat shrink butt splices
    AC Delco ones
    https://www.rockauto.com/en/catalog/...ht+socket,4008
  10. The Following User Says Thank You to Stormyweather For This Post:
  11. #10
    Apr 2010
    Troy
    bethany, ok (okc)
    So turns out the bulbs were in backwards.... no idea how that happened but fixed now
  12. The Following User Says Thank You to zooguy For This Post:
