Results 11 to 20 of 22
Thread: GTP Injectors LT1 Install
12-29-2017, 07:53 AM #11LTx Guru
That's what I thought. The later non-S/C 3.8's were rated at 3.5 bar = 50.75 PSI. Wasn't sure if S/C was the same. Based on 3.5 bar vs. 3.0 bar (43.5 PSI) the conversion would be 33.3 #/HR.
12-29-2017, 08:46 AM #12
I DO NOT recommend running without clips! When I bought my LT1 the injectors were installed without clips, 1500 miles later I started smelling fuel I stopped and looked and the #8 injector had come out of the rail far enough to spray fuel all over the engine compartment and firewall. It was a very scary situation as I was taking my little girl to school when this happened. there are ways to modify the injectors so they can be retained. I HIGHLY recommend going this route!
The Following User Says Thank You to superspirit For This Post:
12-29-2017, 02:04 PM #13
The Following User Says Thank You to 95Hawk326 For This Post:
12-29-2017, 02:19 PM #14
No I dont have any pics, but I got a set of modified injectors from fuel injection connection and they worked great.
If you are a patient person you could mark the new injectors for the clip and take a hacksaw blade and carefully make a retainer clip groove.
take a look here https://fuelinjectorconnection.com/c...l-injector-setLast edited by superspirit; 12-29-2017 at 02:23 PM.
12-29-2017, 03:53 PM #15Xtreme Member
- 7,266
Supporting Memberyou just take a hack saw blade and make the 1 groove that doesn't go all the way around go all the way around. takes 10 mins. that's it.
also there are 2 different part numbers for gtp injectors, one flows 33lb and other 35.99lb so I set injector constant to 34.5lb
The Following 2 Users Say Thank You to SSlowBoat For This Post:
01-03-2018, 09:56 AM #16Xtreme Member
- Apr 2012
- Mike
- 96 Z28, 95 Roadmaster
- Conshohocken, PA
- 1,865
There's the 811 (all plastic) and 737 injectors (plastic with metal bottom). They always seem to run best around the high 33lb/low 34 lb range but I wouldn't worry about the constant that much. Tweak it until the BLMs are centered on 128.
I've had good luck with with doubling up on o-rings to keep the injectors from pushing out of the rails. There's a groove directly above where the lower o-ring sits that you can add another onto. It will prevent the injector from moving too deep into the intake boss because the groove ID is larger.
Sent from my VS995 using Tapatalk96Z M6, ERE-383 #60, AFR 210s, LE cam, 9", Procharger D1, ???whp
01-03-2018, 10:40 AM #17Xtreme Member
- 7,266
01-03-2018, 01:20 PM #18
you could add a wider OD (with same ID as the 811 upper slot) O ring in the upper groove that may help. These pencil injectors are narrower that the stock ones
96 BBB 383/T56
01-03-2018, 09:42 PM #19Xtreme Member
- 7,266
Supporting Member43.5psig behind a uncontained o ring is spelling disaster. scariest moment of my life was #7 spraying on my hot idling motor and header by doing that.
op, I'll get you a pic Sunday when I go to my car for its monthly startup of how to do it right
01-04-2018, 11:30 AM #20Xtreme Member
- Apr 2012
- Mike
- Conshohocken, PA
- 1,865
Never had a viton Felpro o-ring dry out and break before, they're tough as hell and hard enough just to get on. If you really want to be anal you could pop a metal E clip above it in the lower groove.
