Results 1 to 5 of 5
Thread: Rear springs
    The Nitrous Outlet Junkie
    Apr 2010
    Troy
    1994 Firebird Formula
    moore, ok (south okc)
    Default Rear springs
    I don't want to lower my car. However I do need to replace the rear suspension. every place I find only carries lowering springs. what Springs are you guys using for drag racing setups? stock height springs
    Stock springs in mine
    LTX Regular
    Nov 2011
    Marc
    1995 Formula
    magnolia, DE
    For best bang for buck you can use rear springs from a V6 car. But get ones off 93-97 car. The 98-02 cars had the same spring rate in V6 and V8.
    98-02 spring rate = 114lb-in.
    93-97 spring rate = 95lb-in.
    Which should help squat the rear a little better and plant the tires.
    Sent from my A621BL using Tapatalk
    1995 FORMULA M6
  4. The Following User Says Thank You to 95 blackbird For This Post:
  5. #4
    Aug 2009
    Kyle
    '95 Trans Am
    Elizabethtown, Kentucky
    Stock springs
    Sent from my SAMSUNG-SM-G890A using Tapatalk
    Kyle
  6. The Following 2 Users Say Thank You to SexyTransAm For This Post:
  7. #5
    Apr 2010
    Troy
    Quote Originally Posted by SexyTransAm View Post
    Stock springs
    Nice ..... so the my car needs the springs replaced ... where can I get new stock springs
