Results 11 to 20 of 33
Thread: LT1 in my 68 Camaro
12-09-2017, 12:28 PM #1196 BBB 383/T56
12-10-2017, 08:45 AM #12Long Live the Opti
- Sean
- 1999 Twin Turbo Corvette
- Fort Wayne, IN
- 12,072
I'll chime in here on some stuff.
Lloyd and AI both do good jobs with the LT1 OEM heads. I won't say a single bad thing about either. But to properly feed a 383 on the top end, you're going to want to move to a larger runner head because the OEM castings become a choke point higher in the power band. Yes, moving to an aftermarket large runner AFR (220, 227) or Trick Flow head will require the LT4 intake, but that's a cost of playing the game at that point. If you're trying to maximize the potential in the added displacement don't sell your build short by sticking with OEM castings.
12-10-2017, 02:40 PM #13Xtreme Member
- 7,269
Supporting Membertrickflow 23 degree require lt4 intake, 21 degree do not. but you are very correct. @Ltconvert car was choking with the le2 heads, car is an animal now with LE ported trickflows
12-10-2017, 08:45 PM #14Long Live the Opti
- Sean
- Fort Wayne, IN
- 12,072
The Following User Says Thank You to Fastbird For This Post:
12-12-2017, 01:13 PM #15
Machine shop says I shouldn't go above 10:1 compression with aluminum heads. I thought LT1's were good for a little higher compression
12-12-2017, 03:13 PM #16Long Live the Opti
- Sean
- Fort Wayne, IN
- 12,072
12-12-2017, 05:30 PM #17LTX Master
- Aug 2013
- JB
- Atoka,TN
- 531
I'll have to disagree with the machine shop. I have LE Trickflow 21 degree heads with a 12.2:1 compression on 93 non-ethanol pump gas. I can't bad-mouth AI because I've never used them but I will vouch for Lloyd. He's a real professional!
Sent from my SAMSUNG-SM-G900A using TapatalkSame as everybody else...350 small block, double hump heads, 3/4 cam
The Following User Says Thank You to Cathead For This Post:
12-12-2017, 05:35 PM #18Xtreme Member
- 7,269
12-12-2017, 10:58 PM #19LTx Guru
Stock LT1 engine with aluminum heads static CR is 10.4:1. Stock LT4 engine with aluminum heads is 10.8:1. My 381ci w/ LT4 heads is just a bit under 11:1.
Dynamic CR is more important than static CR in determining octane requirement.
What’s the elevation where you live? Higher you go, the more CR your engine can handle.Last edited by Injuneer; 12-12-2017 at 11:02 PM.
12-14-2017, 06:32 AM #20
I will have to talk to him again. I recall he mentioned he only worked on one LT1 before
