Results 11 to 20 of 27
  1. #11
    Nov 2016
    wayne
    96 pontiac ws6
    also i need to tune it now, know it wont fix this but i can tune it and block the code,who is the best tuner for this
  2. #12
    Johnny
    1994 formula A4
    Henderson, TN
    Are you still running the 1996 OBD2 pcm?
    Has the opitspark been replaced?
  3. #13
    Nov 2016
    wayne
    96 pontiac ws6
    yes it is obd 2pcm and no new optispark, the new cap and rotor,did not have a light before my build
  4. #14
    Johnny
    1994 formula A4
    Henderson, TN
    Once you switch to the obd pcm and get it tuned I doubt you will still have the problem
  5. #15
    Nov 2016
    wayne
    96 pontiac ws6
    your saying i should replace the obd2 with an obd1 pcm
  6. #16
    Yes, it's the simplest way. convert to obd1, buy a cable and download tunerpro rt. then you can tune it yourself with the help of a tuner.
  7. #17
    And, there is no misfire detection in OBD-1, which solves that problem.
    But, if you have an auto trans, you may run into problems with the mismatch in the PWM converter lockup strategy differences between OBD-1 and OBD-2.
    http://ltxtech.com/forums/showthread...d-interchanges
  8. #18
    LTX Regular
    Aug 2013
    Gary
    1998 Trans Am
    Florida
    Another possible solution is to have the crank position sensor relearned. It's done by a dealer or someone with the high end scan tools. Normally it is done after replacement of the crank or the sensor but it might help in this case and can't hurt. I think the dealer charge is about $100. Or find someone with a Tech II scantool. The process involves letting the scantool take command of the throttle while it learns the sensor signals.
  9. #19
    Nov 2016
    wayne
    96 pontiac ws6
    the car is a t56 and as for the scan tool we have the snap on tech tool at work (Goodyear) i will see if that has it
  10. #20
    Nov 2016
    wayne
    96 pontiac ws6
    and right now i have the jets DST program software and Websters date logging program
