Results 1 to 6 of 6
Thread: 95 z28 white smoke after idle
11-08-2017, 09:27 PM #1
Okay I am looking at this 95 z28 and the owner says that it was his good friends car for past 15yrs. Owner said it started smoking after new Delco opti was installed due to car misfiring etc. Stated car never overheated and it didn’t smoke prior to the opti going bad.
Curious to see what all your thoughts are on this? I have had Lt1’s before one ran good and other had misfire I could not fix. Below is the parts list and a video of it running (before it would smoke...he did also state he does not drive it since after the opti was put in)
Motor:
383 Stroker LT1, forged eagle crank, forged h beam eagle rods, JE Forged Pistons, Aluminum CFE Stage 3 heads, Cam 239/245 577 577 114 LSA, Brand new Opti spark distributor
Crane lifters, 1.7 roller rockers, ARP studded main caps, ARP head bolts, ARP cam bolts, over sized oil pan
Body:
Less than 80,xxx miles, motor less than 5,xxx miles
Trans:
T-56 bullet proofed - Steel 3rd and 4th gear shift forks, Carbon Fiber syncros
Stage 4 spec puck clutch / Pro 5.0 short shifter
Rear:
7.5 2002 SS 3 channel rear, 3.73 Eaton Posi, Studs, TA girdle, 30 spline axles
Bolt ons:
K&N cold air
1LE intake elbow
Holley 52mm throttle body
Ported intake manifold
Long tube pace setter headers
Offroad Y pipe
Mzeer electric water pump
160 or 180 thermostat
MSD 6AL box
Tuned by Rev Extreme out of Tampa
Walbro 255 Fuel pump (Racetronics 12v constant fuel pump)
Alum drive shaft
Energy suspension
Video of it idling before it smokes (sounds healthy to me)
All inputs appreciated possibly looking at this Friday and it’s a drive and needing a trailer to bring it back.
Sent from my iPhone using TapatalkUsing Tapatalk
11-09-2017, 01:55 PM #2Xtreme Member
- 7,249
11-09-2017, 02:31 PM #3
Ekkk that’s what I was thinking
11-09-2017, 10:35 PM #4
Any other opinions?
11-10-2017, 06:40 AM #5
ok you said it smokes white "After" it warms up? something expanding like a crack in the head or head gasket, white smoke is usually water = Steam, tough call, how does the oil look? any white foam on the oil cap?
11-10-2017, 08:40 AM #6
I haven’t personally went and looked at it just trying to fig out of its work the time and effort renting a trailer like I just did for another car I declined on. And also how long does it take for the oil to show signs of coolant? I notice guys will ouhave “fresh oil” to be nice but in reality they want to hide issues.
