Results 11 to 14 of 14
Thread: Alternator functionality
11-02-2017, 08:49 PM #11The Nitrous Outlet Junkie
- Apr 2010
- Troy
- 1994 Firebird Formula
- moore, ok (south okc)
- 3,274
When I started the car the voltage did not increase from 12.5 volts
Sent from my SM-N910T using Tapatalk94 Formula "budget build" #thebeaterbird
11-02-2017, 08:51 PM #12Xtreme Member
- 7,266
11-02-2017, 08:53 PM #13The FABRICATOR!
- Jul 2011
- 1985 Monte Carlo SS
- southern illinois
- 7,164
You need to make sure the socket on the alternator plug isn't spread out so far it won't engage the blade on the alternator. If that's good, move on to grounds. You need a good clean path to ground from the alternator. If its powder coated or the block is painted where the mounting points are, clean them off. Or you can bolt a cable to the alternator directly to frame. What size is your charge cable and where is it ran to?
11-08-2017, 07:56 PM #14The Nitrous Outlet Junkie
- Apr 2010
- Troy
- 3,274
Fixed .... took it to an alternator shop and had them converted to a single wire alternator
