Results 1 to 10 of 14
Thread: Alternator functionality
11-01-2017, 09:21 PM #1The Nitrous Outlet Junkie
- Apr 2010
- Troy
- 1994 Firebird Formula
- moore, ok (south okc)
- 3,274
I converted my car to carb and got rid of the PCM and wiring harness I'm now running into problems getting the alternator to charge the battery ... I took it off and had it tested three different places alternator is fine how do I get it to charge the battery though. I think it has something to do with the Exciter wire.
A few places people told me to use a 470 Ohm resistor but I'm not sure what to do with that.94 Formula "budget build" #thebeaterbird
11-01-2017, 09:23 PM #2Xtreme Member
- 7,249
11-01-2017, 09:25 PM #3The Nitrous Outlet Junkie
- Apr 2010
- Troy
- 3,274
The other thread was for me to figure out how to get my voltmeter to function I've got that working now. thanks for your help.
However I now know my problem is not with the voltmeter but the alternator and I know very little about how Electronics work so please forgive me for reaching out for help
11-01-2017, 09:27 PM #4Xtreme Member
- 7,249
Supporting Member12v positive to switch, out of switch to resistor, then crimp connector to exciter wire/plug
voltage gauge wired thru a switch, then to the charging wire that runs from battery positive to alternator
that's how both need to be wired.
11-01-2017, 09:29 PM #5LTX Regular
- Aug 2013
- Gary
- 1998 Trans Am
- Florida
- 241
He did tell you how to use it. Connect one end of the resistor to the exciter wire and the other end of the resistor to a switched ignition point.
11-01-2017, 11:37 PM #6LTx Guru
- 2,279
I posted the factory wiring diagram in the other thread, showing the location of the resistor, and how to incorporate it into the voltage gauge and exciter circuit, but that didn't seem to help.
11-02-2017, 12:01 AM #7The Nitrous Outlet Junkie
- Apr 2010
- Troy
- 3,274
Sorry for wasting your times
11-02-2017, 05:37 PM #8The Nitrous Outlet Junkie
- Apr 2010
- Troy
- 3,274
Fingers crossed
11-02-2017, 06:42 PM #9The Nitrous Outlet Junkie
- Apr 2010
- Troy
- 3,274
Well that didn't work ..... I connected it to the switch for my ignition and ran it straight to the alternator single wire connected to the plug any ideas why it won't work?
11-02-2017, 08:47 PM #10LTX Regular
- Aug 2013
- Gary
- 1998 Trans Am
- Florida
- 241
Try measuring the voltage at the resistor end connected to the alternator. It should have about 12v when the ignition switch is on.
How are you determining that the alternator is not working?
By the way, that looks like good work on the resistor insulation.
