Results 1 to 10 of 12
Thread: Long tube headers Reviews
10-25-2017, 09:15 PM #1Lurker
- Oct 2017
- SAM
- 2008 G8 GT 1999 Z28 6M Pewter Sold 15 Q50S
- High Point Nc
- 15
Looking to buy a 1997 Formula, seeking info, what's available as far as in stock brand new in other words what's current in production.
Hows fittment/ finish. Don't want any burned plug wires. Thinking about Headers y pipe wanting to use cat/s and free flowing 3 inch single. Is dual better?
Is AIR injection necessary? I'm guess tune is necessary afterward.
Not a noob to racing, but the LT1 is new to me.
10-25-2017, 10:11 PM #2Xtreme Member
- Apr 2012
- Cameron
- Dover, De
- 2,076
Pacesetter's are tried and true. Never had and issue when my wires were tucked under the headers but I helped @95 blackbird put over the valve cover setup on his car and its looks nice and clears fine.
I run a ORY to a single 3' HF cat and a TSP rumbler exhaust.
All depends how strict your state is on emissions. I have AIR deleted but have to have a separate tune for inspection.2012 Sierra - 5.3, Summit "Stage 1" Truck Cam
Formula Build Thread
10-25-2017, 10:45 PM #3LTx Guru
AIR only runs at startup to help the cats heat up faster, and control emissions from the rich cold start A/F ratio. With long tubes typically moving the cats further from the engine, it would be important for emissions. But, dyno emissions tests generally do not measure cold start emissions. So.... tailpipe check, no problem deleting AIR. Visual check, might need to keep it. In any case, if you delete it you have to delete the diagnostic from the PCM to avoid an SES light (several codes for missing AIR in OBD-2), and it has to be deleted from the PCM in such away that it does not cause a "system not ready" flag, which can be cause for failure hooking up to the DLC connector (depends on state law how many "not ready" flags cause a fail).
There is no performance gain from deleting AIR, since the system only operates for a couple minutes at startup.SOLD - GONE TO A (VERY) GOOD HOME ! - 94 Formula A3+1: 381ci forged stroker - Callies Stealth, Oliver 5.85 billet rods, BME nitrous pistons / CNC LT4 heads / CC solid roller / TH400+GearVendors OD / 4.11 Strange 12-bolt / 300-shot N2O / Spohn Suspension / roll bar / MoTeC M48 Pro engine management system /a few other odds 'n ends.
10-27-2017, 08:20 AM #4Lurker
- Johnny
- 1994 formula A4
- Henderson, TN
- 935
https://www.ebay.com/i/151459584416?chn=ps&dispItem=1
Cheap and im sure there made in China but they work and look great.
Thats what I bought, the y pipe needed a little massaging but they fit PERFECT!! Ive had them for almost a year and they look just as good as the day I put them on
My last car had pacesetters and they were pretty much exactly the same as these but the flange on the pacesetters is not as thick and there not stainless steel like these.
I retightend the bolts after about 200 miles and have been checking them every month or so and they havent loosened at all.
Even if I had a unlimited budget I dont think I would buy anything else but these.Last edited by fullforce; 05-04-2018 at 02:16 PM.
03-03-2018, 06:42 PM #5Lurker
- Feb 2018
- That guy...
- 1994 Trans Am
- Winchester, VA
- 68
Pacesetter LT's have been on both of mine and unless I get really serious and NEED Kooks they will be what I use.
Sent from my N9560 using Tapatalk
03-10-2018, 08:50 PM #6LTX Member
- Oct 2014
- Justin
- 1995 Formula
- Houston, TX
- 82
I'm running LPP/XS-Power. I like them a lot but they don't have provisions for emissions. They're stainless and fit great other than a small contact point on the driver side of the k-member. it barely touched. A couple wacks with a hammer fixed it right up. The only real complaint is it's a pain in the ass to get the oil filter out the a moroso oil pan.
Oh, and I had to clearance one of the driver side primaries. But again, that was because I'm running a moroso oil pan.95 Cyber Grey Formula
396 M6
LE 244/252 .636/.636 110
LE 215cc Trickflows
04-20-2018, 06:43 PM #7
For the money LPP header's are a solid choice. Stainless, stepped primaries and are well made.
04-26-2018, 08:35 AM #8Xtreme Member
- Nov 2008
- Chris
- 1994 Trans Am
- PA, USA
- 2,438
What's the status on the whole LPP situation? Wasn't there some chaos on the forum regarding their rebranded XS Power headers not long ago? My car had a pair of Hooker Supercomps/Hooker ORY that fit pretty good. The removable primary to fit around the steering shaft was slick. Fairly expensive for painted headers, but that was before the chinese stainless craze.
04-26-2018, 05:22 PM #9Xtreme Member
- Apr 2012
- Mike
- 96 Z28, 95 Roadmaster
- Conshohocken, PA
- 1,866
Yeah, they shipped me and a few other people a pacesetter style ORY from a distributor on eBay. It didn't fit their headers and I got my money back. Afaik they stopped doing that and started shipping their own again shortly after. I guess they had a hiccup in production.
Sent from my VS995 using Tapatalk96Z M6, ERE-383 #60, AFR 210s, LE cam, 9", Procharger D1, ???whp
04-27-2018, 12:09 PM #10Xtreme Member
- Mar 2015
- Mike Storm "Stormy"
- 1995 Trans Am
- Washington
- 1,020
- Blog Entries
- 1
Seen a set on Amazon for 154.98.
Free shipping as well.
Sent from my HP Pro Slate 8 using TapatalkLast edited by Stormyweather; 04-27-2018 at 05:07 PM.
