Results 11 to 19 of 19
Thread: Voltage gauges
10-24-2017, 01:56 PM #11The Nitrous Outlet Junkie
- Apr 2010
- Troy
- 1994 Firebird Formula
- moore, ok (south okc)
- 3,274
Like this?
10-24-2017, 02:23 PM #12Xtreme Member
- 7,266
10-25-2017, 04:07 PM #13The Nitrous Outlet Junkie
- Apr 2010
- Troy
- 3,274
Found my instructions and it says to wire it differently ..... just to a regular power and ground. If I touch it across the battery it works great so I'm probably way over thinking this but is this how am actually supposed to wire it on the card board?
10-25-2017, 05:14 PM #14The Nitrous Outlet Junkie
- Apr 2010
- Troy
- 3,274
So I wired it up like the cardboard picture and this is my results
10-25-2017, 05:20 PM #15Xtreme Member
- Mar 2015
- Mike Storm "Stormy"
- 1995 Trans Am
- Washington
- 1,020
- Blog Entries
- 1
Does it work cause I don't see how that works from the drawing.
10-25-2017, 05:22 PM #16The Nitrous Outlet Junkie
- Apr 2010
- Troy
- 3,274
Watch attached video
10-25-2017, 05:44 PM #17Xtreme Member
- Mar 2015
- 1995 Trans Am
- Washington
- 1,020
- Blog Entries
- 1
Ok lol
on the phone using Tapatalk
10-25-2017, 05:47 PM #18
If you do not have 470 ohmn in the line, the field will not be excited and you will get nada.
Not sure if you are getting more than 12v in that video, so if not, you need to will in a resistor in series with the gauge.
Or run the gauge separate from the excite lead.Correlation does not imply causation.
10-25-2017, 06:17 PM #19Xtreme Member
- 7,266
Supporting MemberLast edited by SSlowBoat; 10-25-2017 at 06:20 PM.
