Results 1 to 10 of 19
Thread: Voltage gauges
10-23-2017, 08:11 PM #1The Nitrous Outlet Junkie
- Apr 2010
- Troy
- 1994 Firebird Formula
- moore, ok (south okc)
- 3,274
Voltage gauges
.... okay so after deleting the PCM because I went carburetor. The only thing that works on my gauge cluster is the fuel level and we all know have accurate those are lol .... so I took the plug for the alternator off the wiring harness and I was going to connect that to a voltage gauge. When I did that I didn't get any voltage reading at all if I check at the post I see 12 volts ... so I know this is probably a stupid question but to get the voltage gauge working.
can I just go off the battery or does it have to come off the alternator? Today I removed it and took it to an auto parts store to have it tested and it tested fine
10-23-2017, 08:13 PM #2Xtreme Member
- 7,266
10-23-2017, 10:19 PM #3Xtreme Member
- Mar 2015
- Mike Storm "Stormy"
- 1995 Trans Am
- Washington
- 1,020
- Blog Entries
- 1
You could wire it to the same wire on your ignition switch that go to the coil. So it will only be on with the key.
... on my tablet using Taptalk
10-24-2017, 07:35 AM #4
10-24-2017, 10:18 AM #5LTx Guru
Here's the wiring diagram. If you still have the stock cluster the volts gauge should still be working. Check the "Gages" fuse.
http://shbox.com/1/starter_charging_95.jpgSOLD - GONE TO A (VERY) GOOD HOME ! - 94 Formula A3+1: 381ci forged stroker - Callies Stealth, Oliver 5.85 billet rods, BME nitrous pistons / CNC LT4 heads / CC solid roller / TH400+GearVendors OD / 4.11 Strange 12-bolt / 300-shot N2O / Spohn Suspension / roll bar / MoTeC M48 Pro engine management system /a few other odds 'n ends.
10-24-2017, 11:14 AM #6The Nitrous Outlet Junkie
- Apr 2010
- Troy
- 3,274
I'll check it when I get home but I'm pretty sure that the fuses good. I want to be able to monitor my voltage in case something happens of course.
But now I'm beginning to wonder will the alternator do its job if its connected with the wire on those back going to the battery
And the single wire going into the plug not hooked up
10-24-2017, 12:10 PM #7Xtreme Member
- 7,266
10-24-2017, 12:53 PM #8The Nitrous Outlet Junkie
- Apr 2010
- Troy
- 3,274
Okay ... sorry :/ .... I'm still not quite understanding. .... so how should it be wired ...I am having problems reading the wiring diagram posted ... can yall please post a simple one .... maybe drawn in crayons?
10-24-2017, 01:28 PM #9Xtreme Member
- Mar 2015
- 1995 Trans Am
- Washington
- 1,020
- Blog Entries
- 1
Looks like there's a terminal marked L on the back of the alt that goes to stock cluster and your not using that right?
on the phone using Tapatalk
10-24-2017, 01:32 PM #10Xtreme Member
- 7,266
