Results 1 to 10 of 16
Thread: Rearend movement
10-22-2017, 04:10 PM #1
Rearend movement
Ok so I noticed a while back that I had a little rear end movement. I drove it today and it seems like a has a good bit. When I go around a right hand turn I hear a squeak like the brake squeakers. So any ideas? I checked the c clips. I know its been covered sorry Im wondering if its the Posi
10-22-2017, 04:11 PM #2
Sorry forgot to change my location before posting
10-22-2017, 05:32 PM #3VIP Member
- Dec 2011
- Mark
- Altoona, PA
- 809
Had the same problem on my sons car. Here's what our issue was. The rotor was rubbing the caliper bracket on the driver side when going around a turn. Just enough to sound like a brake squeal issue. Put new c-clips in it to see if that would help but still had the same issue. After tearing it apart again I noticed the the rotor wasn't anywhere close to being centered on the caliper bracket. I ended up using a washer as a spacer where the bracket bolts to the housing to move it out some to clear the rotor. Used on both bolts. Washer between caliper bracket and housing mount. Not sure why it started or what changed to cause the noise. Just put gears in it with all new bearing and still had the same issue so washers went back in. Was only on drivers side. Solved our problem.
Sent from my iPad using TapatalkStock bottom end, Impala head gaskets, Stock heads w/stage 2 port polish Comp beehive springs, Crane 1.6 RR's, Thunder Racing cam, Cloyes Billet True Roller TC, Long tubes, custom true dual 3" w/X-pipe, Ported intake with 58mm TB, 36lb injectors, PCMforless chip, Tick Performance stage 3 M6, Strange S60 4:10's True Trac 35 spline axles, MSD complete Ignition system, Summit electric water pump and a ton of other upgrades.
10-22-2017, 05:55 PM #4
Thanks I will have to try it. mine is only the drives side to. I was also wondering if maybe the groove the c clip runs in wasnt worn and made it move more.
10-22-2017, 07:19 PM #5Xtreme Member
- 7,269
Supporting MemberI have the same issue, just driving it until it wears away enough
10-23-2017, 11:43 AM #6
I thought about that to but want to make sure its not something that will hurt anything. But I also need to fix the rearend movement. If you get it up to about 70 and it start moving it gets bad fast and its like its starting to fishtail so need to address that fast
10-23-2017, 11:46 AM #7VIP Member
- Dec 2011
- Mark
- Altoona, PA
- 809
Does it have a panhard bar on it? Panhard bar and lower control arms should keep that in check. I would check all of your bushings.
10-23-2017, 06:44 PM #8
Has factory rear suspension other than lower control arms they are factory just boxed all bushings are good. I cant move the rearend at all when its jacked up just the axles
10-24-2017, 02:16 PM #9Xtreme Member
- Mar 2015
- Mike Storm "Stormy"
- 1995 Trans Am
- Washington
- 1,020
- Blog Entries
- 1
Panhard bar. Get one with Polly one side and heim joints. Haven't done one on my trans but the one I put in my gen 3 big difference in no movenent. Just was a chore to center but not bad.
10-24-2017, 02:20 PM #10Xtreme Member
- 7,269
Supporting Memberop, check the caliper bracket, bet you see wear marks. If your car is feeling squirrelly above 70 check your tires then your panhard.
does your car have the factory panhard brace? I've seen people remove them and then the bracket flexes on the body side
Sent from my SAMSUNG-SM-G935A using TapatalkLast edited by SSlowBoat; 10-24-2017 at 02:22 PM.
