Results 11 to 20 of 21
Thread: 0 miles motor what oil do I run?
10-10-2017, 06:36 PM #11
The Following User Says Thank You to superspirit For This Post:
10-10-2017, 07:03 PM #12Xtreme Member
- Mar 2015
- Mike Storm "Stormy"
- 1995 Trans Am
- Washington
- 1,020
- Blog Entries
- 1
no, synthetic - but if you are planing to use it wait like tubby said till after.
10-10-2017, 07:26 PM #13The Nitrous Outlet Junkie
- Apr 2010
- Troy
- 1994 Firebird Formula
- moore, ok (south okc)
- 3,274
Conventional oil is cheaper and I change it probably prematurely at around 2,000 miles or less. So i'll stick to that. I just didn't know if somebody made a brand of oil that's intended for shorter intervals and stronger protection for a motor that's going to be beat on really hard.
10-10-2017, 07:28 PM #14The Nitrous Outlet Junkie
- Apr 2010
- Troy
- 3,274
With the racecar the oil gets changed once it gets to be a little brown on the dipstick. .... it never get to look dark brown or black.
10-10-2017, 07:49 PM #15LTX Regular
- Sep 2015
- Brandon++S
- 1997 camaro z28
- Alabama
- 198
Castrol GTX here...warm up cycle then changed. 500 miles changed again, now regular intervals.
10-10-2017, 09:00 PM #16Xtreme Member
- 7,249
10-10-2017, 09:24 PM #17Xtreme Member
- Apr 2012
- Mike
- 96 Z28, 95 Roadmaster
- Conshohocken, PA
- 1,862
I was told to run conventional for the first 1k, 5w30
10-11-2017, 07:10 AM #18
Rotella 15w40 T3 stuff.
Its cheap, and I have a bunch of it in the garage. So far no issues with it.
Seeing 30-40psi at idle makes me feel warm and fuzzy. Loss of HP be damned.Correlation does not imply causation.
10-11-2017, 07:15 AM #19Xtreme Member
- 7,249
10-11-2017, 07:29 AM #20The Nitrous Outlet Junkie
- Apr 2010
- Troy
- 3,274
I'm around 11.0 - 11.5 compression ratio
