Results 1 to 2 of 2
    The Nitrous Outlet Junkie
    Apr 2010
    Troy
    1994 Firebird Formula
    moore, ok (south okc)
    Default Chop DS or yoke?
    Okay my drive shaft is a little bit too long with the yolk that I have and need to be short and a little over an inch. So what would be better to cut? the length off of the yoke because it's a little bit long or shorten the driveshaft and re-balance the shaft?
    Personally I would buy a shorter yoke. just be sure you still have an inch of play after it's installed so it doesn't bottom out.
