Results 1 to 1 of 1
    The Nitrous Outlet Junkie
    Apr 2010
    Troy
    1994 Firebird Formula
    moore, ok (south okc)
    Default Electronic fuel pressure gauge
    This is not the cheap $70 gauge from autometer this is a electronic stepper motor fuel pressure gauge 2 5/8 inch zero to 100 PSI ... I now have a carburetor so I don't need this high of a pressure gauge. The reason I purchased this more expensive gauge is because I ran my pressure gauge inside the car and I didn't want to run a fuel line inside the car that could potentially leak causing a huge fire hazard under the dash.
    $175 o.b.o. and I'm open to trades
